查看: 2598|回复: 1
[求助]SPLINE的橡皮筋问题
发表于 2002-6-2 01:03:00 | 显示全部楼层 |阅读模式
版主或高手:
  在ARX中我需要用户自画样条曲线。1.如果用acedGetPoint得到系列点再画,则用户感觉不直观。2.如果用 acedIinitGet边拾点边橡皮筋,则只是直线。3.如果用acedCommand,并用钩子函数检测消息,可以得到曲线橡皮筋,而键盘、鼠标及弹出菜单的检测相当复杂,甚至不能。
  还有其它办法吗?请大师一定赐教!!!
发表于 2002-6-20 21:34:00 | 显示全部楼层
aaa
这段代码可以动态拉出一个SPLINE橡皮筋, 并以RButtonDown结束.
但存在一些问题. 谁知道如果解决请一定告诉我:
1.无法Osnap  2.如果想使用键盘回车结束绘制,如果检测?
void drag()
        int                                track, type;
        struct resbuf        result;
        AcGePoint3d                pt;
        //spline的橡皮筋
        AcDbBlockTable                        *pBlockTable;
        AcDbBlockTableRecord        *pBlockTableRecord;
        AcDbObjectId                        idSpline;
        AcDbSpline                                *pSpline;
        AcGePoint3dArray                pts;
        pts.append(AcGePoint3d(0, 0, 0));
        acdbCurDwg()->getBlockTable(pBlockTable, AcDb::kForRead);
        pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
        pBlockTable->close();
        track = 1;
        while (track > 0)
                acedGrRead(track, &type, &result);
                pt.x = result.resval.rpoint[X];
                pt.y = result.resval.rpoint[Y];
                pt.z = result.resval.rpoint[Z];
                //acutPrintf("\n(track = %d, type = %d, %lf,%lf, %lf)",        track, type, pt.x, pt.y, pt.z);
                if (type == 2)        // keyboard
                        //result.resval
                if (type == 3)        // LButtonDown
                        pts[pts.length() - 1] = pt;
                        pts.append(pt);
                else if (type == 5)                // MouseMove
                        if (pts.length() >= 2)
                                if (acdbOpenObject(pSpline, idSpline, AcDb::kForWrite) == Acad::eOk)
                                        pSpline->erase();
                                        pSpline->close();
                                pSpline = new AcDbSpline(pts);
                                pBlockTableRecord->appendAcDbEntity(idSpline, pSpline);
                                pSpline->close();
                else if (type == 25)                // RButtonDown
                                pSpline->erase();
                                pSpline->close();
                        pts.removeLast();
                                pSpline->close();
                        track = 0;
        pBlockTableRecord->close();
GMT+8, 2025-5-22 14:14 , Processed in 0.166470 second(s), 24 queries , Gzip On.
