查看: 1917|回复: 0
c# 打印,在手册上操的代码加以改进出错
发表于 2011-10-8 21:28:17 | 显示全部楼层 |阅读模式
    这是我做的一个批量打印程序,在手册上操了打印的代码,编译没问题。运行时有三行代码有异常,这三行是完全在手册上操的。以下是全代码,请各位大侠多多批教,谢谢!
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.PlottingServices;
namespace AllBlock
    public class Class1
        //public void Init()
            public static Document doc = Application.DocumentManager.MdiActiveDocument;
            public static Database db = doc.Database;
            public static Editor ed = doc.Editor;
        [CommandMethod("ba")]
        public void ba()
            //Init();
            TypedValue[] tv = new TypedValue[1];
            tv.SetValue(new TypedValue((int)DxfCode.BlockName, "a4"),0);
            // 赋值过滤条件给 SelectionFilter 对象    Assign the filter criteria to a SelectionFilter object
            SelectionFilter acSelFtr = new SelectionFilter(tv);
            // 要求在图形区域中选择对象    Request for objects to be selected in the drawing area
            PromptSelectionResult acSSPrompt = ed.SelectAll(acSelFtr);
            // 如果提示状态是 OK,对象就被选择了    If the prompt status is OK, objects were selected
            if (acSSPrompt.Status == PromptStatus.OK)
                SelectionSet acSSet = acSSPrompt.Value;
                Application.ShowAlertDialog("Number of objects selected: " +acSSet.Count.ToString());
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    foreach (SelectedObject sobj in acSSet)
                        BlockReference bref = tr.GetObject(sobj.ObjectId, OpenMode.ForRead) as BlockReference;
                        ed.WriteMessage("\n块的名称是: " + bref.Name);
                        ed.WriteMessage("\n块的插入位置是:  "+ bref.Position.ToString());
                        Extents3d exSize = bref.GeometricExtents;
                        Point2d pStart = Point3dToPoint2d(exSize.MinPoint);
                        Point2d pEnd = Point3dToPoint2d(exSize.MaxPoint);
                        ed.WriteMessage("\n块的大小是: 长{0},宽{1}", pEnd.X-pStart.X,pEnd.Y-pStart.Y);
                        ed.WriteMessage("\n块的旋转角度是: " + bref.Rotation * 180 / 3.1415926);
                        int a = Plot(pStart, pEnd, 0, 3);
            else
                Application.ShowAlertDialog("Number of objects selected: 0");
        private int Plot(Point2d pMin, Point2d pMax, int angle, int size)
                //设置布局管理器为当前布局管理器
                LayoutManager layoutMan = LayoutManager.Current;
GMT+8, 2024-11-25 20:29 , Processed in 0.164022 second(s), 23 queries , Gzip On.
