- 积分
- 17561
- 明经币
- 个
- 注册时间
- 2011-9-16
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
在网上载了一段打断相交直线的LSP,就是很多人都知道的breakall,下面是代码.
本人刚接触LSP的编程,额、、不到一个月,呵呵,所以现在只会修改里面的命令(别笑哈)!
下面的代码我去掉了几个命令,只留了我需要的3个,不知道算不算侵权,呵呵!
现在我想叫大家帮忙的是:
怎么把那3个命令(BreakAll、BreakWith、BreakSelected)合并成一个命令,效果是这样的:
命令: dd
输入选项 [全部(A)/相对(W)/已选(S)]<全部>:
额,不知道我表达的大家能看懂不,有什么不详细的地方大家可以提出来,谢谢!
 - (defun break_with (ss2brk ss2brkwith self /
- cmd intpts lst masterlist
- ss ssobjs onlockedlayer
- ssget->vla-list list->3pair get_interpts
- break_obj
- (vl-load-com)
- (defun onlockedlayer (ename / entlst)
- (setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
- (= 4 (logand 4 (cdr (assoc 70 entlst))))
- (defun ssget->vla-list (ss / i ename lst)
- (setq i -1)
- (while (setq ename (ssname ss (setq i (1+ i))))
- (setq lst (cons (vlax-ename->vla-object ename) lst))
- lst
- (defun list->3pair (old / new)
- (while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
- old (cdddr old)
- (reverse new)
- (defun get_interpts (obj1 obj2 / iplist)
- (if (not
- (vl-catch-all-error-p
- (setq
- iplist (vl-catch-all-apply
- 'vlax-safearray->list
- (list
- (vlax-variant-value
- (vla-intersectwith obj1 obj2 acextendnone)
- iplist
- (defun break_obj (ent brkptlst / brkobjlst
- en enttype maxparam closedobj
- minparam obj obj2break p1param
- p2 p2param
- (setq obj2break ent
- brkobjlst (list ent)
- enttype (cdr (assoc 0 (entget ent)))
- (foreach brkpt brkptlst
- (if brkobjlst
- (progn
- (if (not (numberp (vl-catch-all-apply
- 'vlax-curve-getdistatpoint
- (list obj2break brkpt)
- (foreach obj brkobjlst
- (if (numberp (vl-catch-all-apply
- (list obj brkpt)
- (setq obj2break obj)
- (cond
- ((and (= "SPLINE" enttype)
- (vlax-curve-isclosed obj2break)
- (setq p1param (vlax-curve-getparamatpoint obj2break brkpt)
- p2 (vlax-curve-getpointatparam
- obj2break
- (+ p1param 0.000001)
- (command "._break"
- obj2break
- "_non"
- (trans brkpt 0 1)
- "_non"
- (trans p2 0 1)
- ((= "CIRCLE" enttype)
- obj2break
- obj2break
- "_non"
- (trans brkpt 0 1)
- "_non"
- (trans p2 0 1)
- (setq enttype "ARC")
- ((and (= "ELLIPSE" enttype)
- p2param (+ p1param 0.000001)
- minparam (min p1param p2param)
- maxparam (max p1param p2param)
- obj (vlax-ename->vla-object obj2break)
- (vlax-put obj 'startparameter maxparam)
- (vlax-put obj 'endparameter (+ minparam (* pi 2)))
- (t
- (setq closedobj (vlax-curve-isclosed obj2break))
- obj2break
- "_non"
- (trans brkpt 0 1)
- "_non"
- (trans brkpt 0 1)
- (if (not closedobj)
- (setq brkobjlst (cons (entlast) brkobjlst))
- (if (and ss2brk ss2brkwith)
- (progn
- (foreach obj (ssget->vla-list ss2brk)
- (if (not (onlockedlayer (vlax-vla-object->ename obj)))
- (progn
- (setq lst nil)
- (foreach intobj (ssget->vla-list ss2brkwith)
- (if (and (or self (not (equal obj intobj)))
- (setq intpts (get_interpts obj intobj))
- (setq lst (append (list->3pair intpts) lst))
- (if lst
- (setq masterlist
- (cons (cons (vlax-vla-object->ename obj) lst)
- masterlist
- (if masterlist
- (foreach obj2brk masterlist
- (break_obj (car obj2brk) (cdr obj2brk))
- (princ)
- ;-------------------------------------------打断所有直线
- (defun c:breakall (/ cmd ss)
- (command "._undo" "_begin")
- (setq cmd (getvar "CMDECHO"))
- (setvar "CMDECHO" 0)
- (prompt "\nSelect All objects to break & press enter: ")
- (if (setq ss
- (ssget
- '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))
- (Break_with ss ss nil)
- (setvar "CMDECHO" cmd)
- (command "._undo" "_end")
- (princ)
- (defun c:BreakObject (/ cmd ss1 ss2)
- (prompt "\nSelect single object to break: ")
- (if
- (and (setq
- ss1 (ssget
- "+.:E:S"
- '((0
- "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"
- (not (redraw (ssname ss1 0) 3))
- (not
- (prompt
- "\n*** Select object(s) to break with & press enter: ***"
- (setq
- ss2 (ssget
- '((0
- (not (redraw (ssname ss1 0) 4))
- (Break_with ss1 ss2 nil)
- (princ)
- ;-----------------------------------用所选直线打断其他线(所选直线不打断)
- (defun c:BreakWith (/ cmd ss1 ss2)
- (defun ssredraw (ss mode / i num)
- (setq i -1)
- (redraw (ssname ss i) mode)
- (prompt "\nSelect object(s) to break & press enter: ")
- (if
- (and (setq
- ss1 (ssget
- '((0
- (not (ssredraw ss1 3))
- (not
- (prompt
- (setq
- ss2 (ssget
- '((0
- (not (ssredraw ss1 4))
- (break_with ss1 ss2 nil)
- (princ)
- ;------------------------有交点处全打断(只限所选直线)
- (defun c:BreakSelected (/ cmd ss1 ss2)
- (defun gettouching (sscros / ss lst lstb lstc objl)
- (and
- (setq lstb (vl-remove-if 'listp (mapcar 'cadr (ssnamex sscros)))
- objl (mapcar 'vlax-ename->vla-object lstb)
- (setq
- ss
- (ssget
- "_A"
- (list
- (cons 0
- (cons 410 (getvar "ctab"))
- (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
- (setq lst (mapcar 'vlax-ename->vla-object lst))
- (mapcar
- '(lambda (x)
- (mapcar
- '(lambda (y)
- (if (not
- (vl-catch-all-apply
- '(lambda ()
- (vlax-safearray->list
- (vla-intersectwith y x acextendnone)
- (setq lstc (cons (vlax-vla-object->ename x) lstc))
- objl
- lst
- lstc
- (setq ss1 (ssadd))
- (if
- (and (not
- (prompt "\nSelect object(s) to break with & press enter: ")
- (setq
- ss2 (ssget
- '((0
- (mapcar '(lambda (x) (ssadd x ss1)) (gettouching ss2))
- (break_with ss2 ss1 nil)
- (princ)
