查看: 2675|回复: 3
这个是病毒吗
发表于 2011-11-19 08:42:24 | 显示全部楼层 |阅读模式
这个是病毒吗?每次打开CAD都会在C盘版生成这个文件,删了还是会生成的....
gys.lsp内容如下:::
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs1 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs2 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs3 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs4 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs5 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs6 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs7 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs8 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs9 "")(setvar "CMDECHO" 1)(princ))
(defun c:()(setvar "CMDECHO" 0)(setq ss(ssget))(command "change" ss "" "p" "c" gys_dd_cs10 "")(setvar "CMDECHO" 1)(princ))
发表于 2011-11-19 08:52:27 | 显示全部楼层
我这里也有,非常苦恼,谁帮忙解决一下
发表于 2011-11-19 10:44:35 | 显示全部楼层
呵呵.坐沙发的老大,貌似你应该能解决啊.把那些与CAD启动后自动加载的东东删除比如acad.lsp,acad2004.lsp,acad.fas,acadapp.lsp等,一般在CAD的安装路径和支持路径下,要删除之前注意备份哦,以免删除了你有用的lsp.当然最好是打开这些文件解读一下,该删除才删除.删除错了也不怕,顶多是重装个CAD,或者从其它电脑里拷删除的文件.
再把你们说的这个全盘清除.应该就可以了吧
发表于 2011-11-19 10:53:03 | 显示全部楼层
gys_dd_cs1是什么定义?
GMT+8, 2025-4-29 03:31 , Processed in 0.229484 second(s), 29 queries , Gzip On.
