查看: 2477|回复: 1
一个测量立面图点标高的程序。
发表于 2011-12-1 11:33:08 | 显示全部楼层 |阅读模式
贡献一个自编的求点标高的程序。基线可以是水平线,即普通的标高问题。也可以是标高有变化的曲线,比如桥面上的构筑物,或者路面的围墙挡土墙等基线不平的情况。欢迎指正。自己觉得可以用,但构思不算巧妙,算是笨方法。
(defun c:test()
  (vl-load-com)
  (setq acadobject (vlax-get-acad-object))
  (setq acaddocument (vla-get-activedocument acadobject))
  (setq mspace (vla-get-modelspace acaddocument))
  (setq bl (car (entsel "\n CHOOSE a BASE LINE:")))
  (setq blv (vlax-ename->vla-object bl)
        blst (vlax-curve-getstartpoint blv)
        blend (vlax-curve-getendpoint blv))
  (setq blstx (car blst))
  (setq blendx (car blend))
  (setq blsty (cadr blst))
  (setq blendy (cadr blend))
   (if (> blstx blendx)
        (setq x0 blstx)
        (setq blstx blendx)
        (setq blendx x0)
  (while (= "")
     (setq tp (getpoint "\n CHOOSE A POINT TO CHECK LEVEL:"))
       (if (< blstx (car tp) blendx)
             (if (= blsty blendy)
               (setq hei (- (cadr tp) blendy))
               (setq tpinser(distpoint tp blv))
               (setq hei(- (cadr tp) (cadr tpinser)))
                (print (strcat "THIS POINT LEVEL IS:"  "-------------" "[ " (rtos hei) " ]"))
                (prin1)
       (if (or (> blstx (car tp)) (< blendx (car tp)))
                  (prin1)
                  (print (strcat"---------------------------------------------" "THIS POINT IS INVALID "  ))
                  (prin1)
               )  ; end if
             )   ; end progn
          )     ;end if
    )  ; end while
(defun distpoint(sp vlacurve)
         (setq sp1 (list (car sp)  (- (cadr sp) 100000) 0.0))
         (setq sp2 (list (car sp)  (+ (cadr sp) 100000) 0.0))
         (setq downv (vlax-make-safearray vlax-vbdouble'(0 . 2)))
         (vlax-safearray-fill downv sp1)
         (setq upv (vlax-make-safearray vlax-vbdouble'(0 . 2)))
         (vlax-safearray-fill upv sp2)
         (setq addlinev (vla-addline mspace upv downv))
         (setq crossv (vla-IntersectWith vlacurve addlinev acExtendNone))
         (setq addline (vlax-vla-object->ename addlinev))
         (command "erase" addline "")
         (setq cross (vlax-safearray->list (vlax-variant-value crossv)))
发表于 2013-6-16 09:23:55 | 显示全部楼层
能增加图面标注 的功能就更好
GMT+8, 2025-4-6 14:31 , Processed in 0.412781 second(s), 30 queries , Gzip On.
