查看: 2793|回复: 0
程序自动加载cui文件成功但没有显示(kean的例子)
发表于 2011-12-2 17:41:29 | 显示全部楼层 |阅读模式
问题如题,加载后没显示,手工卸掉后,再运行bm有显示~~疑惑~~
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Customization;
using System;
using System.Collections.Specialized;
namespace PartialCUI
  public class Commands : IExtensionApplication
    public void Initialize()
      BuildMenuCUI();
    public void Terminate()
    [CommandMethod("bm")]
    public void BuildMenuCUI()
      const string myCuiFile = "c:\\kean.cui";
      const string myCuiFileToSend = "c:/kean.cui";
      const string myCuiSectionName = "Kean";
      Editor ed =
        Application.DocumentManager.MdiActiveDocument.Editor;
      string mainCui =
        Application.GetSystemVariable("MENUNAME") + ".cui";
      CustomizationSection cs =
        new CustomizationSection(mainCui);
      PartialCuiFileCollection pcfc = cs.PartialCuiFiles;
      if (pcfc.Contains(myCuiFile))
        ed.WriteMessage(
          "\nCustomization file \""
          + myCuiFile
          + "\" already loaded."
      else{
        if (System.IO.File.Exists(myCuiFile))
          ed.WriteMessage(
            + myCuiFile
            + "\" exists - loading it."
          LoadMyCui(myCuiFileToSend);
        else
          ed.WriteMessage(
            + myCuiFile
            + "\" does not exist - building it."
          // Create a customization section for our partial menu
          CustomizationSection pcs = new CustomizationSection();
          pcs.MenuGroupName = myCuiSectionName;
          // Let's add a menu group, with two commands
          MacroGroup mg =
            new MacroGroup(myCuiSectionName, pcs.MenuGroup);
          MenuMacro mm1 =
            new MenuMacro(mg, "Cmd 1", "^C^CCmd1", "ID_MyCmd1");
          MenuMacro mm2 =
            new MenuMacro(mg, "Cmd 2", "^C^CCmd2", "ID_MyCmd2");
          // Now let's add a pull-down menu, with two items
          StringCollection sc = new StringCollection();
          sc.Add("POP15");
          PopMenu pm =
            new PopMenu(
            myCuiSectionName,
            sc,
            "ID_MyPop1",
            pcs.MenuGroup
          PopMenuItem pmi1 =
            new PopMenuItem(mm1, "Pop Cmd 1", pm, -1);
          PopMenuItem pmi2 =
            new PopMenuItem(mm2, "Pop Cmd 2", pm, -1);
          // Finally we save the file and load it
          pcs.SaveAs(myCuiFile);
    private void LoadMyCui(string cuiFile)
  Document doc =    Application.DocumentManager.MdiActiveDocument;  object oldCmdEcho =    Application.GetSystemVariable("CMDECHO");  object oldFileDia =    Application.GetSystemVariable("FILEDIA");  Application.SetSystemVariable("CMDECHO", 0);  Application.SetSystemVariable("FILEDIA", 0);  doc.SendStringToExecute(    "_.cuiload "    + cuiFile    + " ",    false, false, false  );  doc.SendStringToExecute(    "(setvar \"FILEDIA\" "    + oldFileDia.ToString()    + ")(princ) ",    false, false, false  );  doc.SendStringToExecute(    "(setvar \"CMDECHO\" "    + oldCmdEcho.ToString()    + ")(princ) ",    false, false, false  );
GMT+8, 2025-5-25 18:15 , Processed in 0.154925 second(s), 23 queries , Gzip On.
