查看: 2283|回复: 0
路过的高手帮忙看看这个程序
发表于 2011-12-4 12:56:25 | 显示全部楼层 |阅读模式
(defun C:tt()
(setq scl (getreal "\n缩放比例:"))
(setq ss (ssget))
(setq n 0)
(repeat (sslength ss)
   (setq ssn (ssname ss i))
   (setq ssdata (entget ssn))
   (setq sstyp (cdr (assoc 0 ssdata)))
  (if (= sstyp "LINE")
    (setq enam (ssname ss n))
    (setq edat (entget enam))
    (setq pt1 (cdr (assoc 10 edat)))
  (if (= sstyp "TEXT")
    (setq ename (ssname ss n))
    (setq edata (entget ename))
    (setq height (assoc 40 edata))
    (setq pt (cdr (assoc 10 edata)))
    (setq pt_n (mapcar '+ pt pt1))
    (setq edata (subst (cons 40 (* scl (cdr height))) height edata))
    (setq edata (subst (cons 72 4) (assoc 72 edata) edata))
    (setq edata (subst (cons 11 pt_n) (assoc 11 edata) edata))
  (entmod edata)
  (entupd ename)
(setq n (1+ n))
想实现上面图片的功能,出现错误不能解决,帮帮新手吧!
GMT+8, 2025-6-3 16:01 , Processed in 0.229931 second(s), 30 queries , Gzip On.
