查看: 7118|回复: 21
求任意多条线延伸或剪短直接形成封闭多边形
发表于 2011-12-6 19:19:25 | 显示全部楼层 |阅读模式
路过滴大侠弄下啊谢谢
发表于 2011-12-6 19:24:49 | 显示全部楼层
Command: pedit
Select polyline or [Multiple]: m
Select objects: Specify opposite corner: 4 found
Select objects:
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
Join Type = Extend
Enter fuzz distance or [Jointype] <0.0000>: 0.5
3 segments added to polyline
依需求细心回应
 楼主| 发表于 2011-12-6 19:29:33 | 显示全部楼层
Andyhon 发表于 2011-12-6 19:24
Command: pedit
谢谢但是不行哦大侠
发表于 2011-12-6 19:48:37 | 显示全部楼层
Command: '_dist Specify first point:  Specify second point:
Distance = 37.1083,  Angle in XY Plane = 73,  Angle from XY Plane = 0
Delta X = 10.6713,  Delta Y = 35.5408,   Delta Z = 0.0000
Command:
DIST Specify first point:  Specify second point:
Distance = 39.9582,  Angle in XY Plane = 148,  Angle from XY Plane = 0
Delta X = -33.7924,  Delta Y = 21.3245,   Delta Z = 0.0000
Command: pedit
Select objects:
Join Type = Extend
Enter fuzz distance or [Jointype] <0.0000>: 40
参与人数 1金钱 +5 收起 理由
flytoday + 5 赞一个!
 楼主| 发表于 2011-12-6 20:28:23 | 显示全部楼层
大侠命令是什么啊
发表于 2011-12-6 21:41:26 | 显示全部楼层
这些代码不会用。。。求教。。。
发表于 2011-12-7 08:43:31 | 显示全部楼层
Andyhon 教会您用自带命令搞定,如果还看不懂的话,用程序吧,别告诉我你还是搞不定。
关键模糊距离如何确定?仔细看一下Andyhon 的帖子,琢磨一下。模糊距离不一样,结果可能不一样。
发表于 2011-12-7 08:54:21 | 显示全部楼层
谢谢楼主分享!
发表于 2011-12-7 09:04:23 | 显示全部楼层
CAD命令:pe-m-选中-y(转为多段线:是)-j(合并)-输入模糊距离-enter
 楼主| 发表于 2011-12-7 09:08:02 | 显示全部楼层
xiaxiang 您太强大了
GMT+8, 2025-5-19 13:46 , Processed in 0.200503 second(s), 29 queries , Gzip On.
