查看: 5127|回复: 16
文字替代(解决文字乱码用)
发表于 2011-12-11 10:10:38 | 显示全部楼层 |阅读模式
  1. ;文字替代(解决文字乱码用)
  2. (defun c:KK( / lb_eng lb_chn lb_sech lb_tt1 lb_tt2 lb_a1 lb_a2 lb_hh)
  3.   (setvar "REGENMODE" 0)
  4.   (setq lb_eng (getstring "英文替代<Simplex>:") lb_chn (getstring "中文替代<Hztxt>:"))
  5.   (if (= "" lb_eng)(setq lb_eng "simplex"))
  6.   (if (= "" lb_chn)(setq lb_chn "hztxt"))
  7.   (setq lb_sech (tblnext "style" t))
  8.   (while lb_sech
  9.     (setq lb_tt1 (cdr(assoc 3 lb_sech)) lb_tt2 (cdr(assoc 4 lb_sech)))
  10.     (if (or (<= (strlen lb_tt1) 4)
  11.             (/= "." (strcase(substr lb_tt1 (- (strlen lb_tt1) 3) 1)))
  12.         )
  13.         (setq lb_tt1 (strcat lb_tt1 ".shx"))
  14.     )
  15.     (if (or (<= (strlen lb_tt2) 4)
  16.             (/= "." (strcase(substr lb_tt2 (- (strlen lb_tt2) 3) 1)))
  17.         )
  18.         (if (/= "" lb_tt2)(setq lb_tt2 (strcat lb_tt2 ".shx")))
  19.     )
  20.     (if (/= ".TTF" (strcase(substr lb_tt1 (- (strlen lb_tt1) 3) 4)))
  21.       (progn
  22.         (if (null (findfile lb_tt1))(setq lb_a1 lb_eng)(setq lb_a1 lb_tt1))
  23.         (if (= "" lb_tt2)
  24.           (setq lb_a2 "")
  25.           (if (null (findfile lb_tt2))(setq lb_a2 lb_chn)(setq lb_a2 lb_tt2))
  26.         )
  27.         (setq lb_hh (strcat lb_a1 "," lb_a2))
  28.         (command "-style" (cdr(assoc 2 lb_sech)) lb_hh "" "" "" "" "" "")
  29.       )
  30.       (if (null (findfile lb_tt1))(command "-style" (cdr(assoc 2 lb_sech)) (strcat lb_eng "," lb_chn) "" "" "" "" "" ""))
  31.     )
  32.     (setq lb_sech (tblnext "style"))
  33.   )
  34. (setvar "REGENMODE" 1)
  35. (command "regen")
  36. )
该贴已经同步到 【KAIXIN】的微博
参与人数 3明经币 +3 收起 理由
自贡黄明儒 + 1 赞一个!
MaKaiJin + 1
cabinsummer + 1 赞一个!
发表于 2011-12-12 03:13:33 | 显示全部楼层
;修改版本
(defun c:ql (/ lb_eng lb_chn lb_sech lb_tt1 lb_tt2 lb_a1 lb_a2 lb_hh tst)
  (setvar "cmdecho" 0)
  (if (= "" lb_eng)
    (setq lb_eng "Simplex")
  (if (= "" lb_chn)
  (while lb_sech
    (setq lb_tt1 (cdr (assoc 3 lb_sech))
   lb_tt2 (cdr (assoc 4 lb_sech))
   tst nil
    (if (not (wcmatch lb_tt1 "*`.*"))
    (if (and
   (not (wcmatch lb_tt2 "*`.*"))
   (/= "" lb_tt2)
    (if (not (wcmatch (strcase lb_tt1) "*`.TTF"))
     (setq lb_a1 lb_eng
    tst t
   (setq lb_a1 lb_tt1)
(if (/= "" lb_tt2)
  (setq lb_a2 lb_chn
        tst t
       (setq lb_a2 lb_tt2)
(if (= "" lb_tt2)
   (setq lb_hh lb_a1)
(if tst
   (command "-style" (cdr (assoc 2 lb_sech)) lb_hh "0" "" "" "" "" "")
  (command "regen")
  (setvar "cmdecho" 1)
发表于 2020-9-27 10:43:38 | 显示全部楼层
顶起来,,谢谢楼主及评论区大神的分享
发表于 2024-10-22 14:19:08 | 显示全部楼层
好东西,顶上去,感谢地板的lsp代码
发表于 2011-12-11 10:27:18 | 显示全部楼层
好程序啊,顶一个。
发表于 2011-12-11 13:12:09 | 显示全部楼层
好程序,谢谢。
发表于 2011-12-12 10:18:40 | 显示全部楼层
真是个高手啊
 楼主| 发表于 2012-4-11 19:27:38 | 显示全部楼层
好东西,顶上去!
发表于 2012-4-29 08:50:43 来自手机 | 显示全部楼层
好东西,一定要顶上去。
发表于 2012-4-29 09:25:32 | 显示全部楼层
(defun c:nx
            (/ thisdrawing acaddocument txtstyles txtlayer fontfile)
  (setq thisdrawing (vla-get-activedocument (vlax-get-acad-object)))
  (setq acaddocument (vla-get-activedocument (vlax-get-acad-object)))
  (setq txtstyles (vla-get-textstyles thisdrawing))
  (vlax-for txtstyle txtstyles
      (setq fontfile (vla-get-fontfile txtstyle))
      (setq bigfile (vla-get-bigfontfile txtstyle))
      (if (not (wcmatch fontfile "*.ttf,*TTF"))
          (vla-put-fontfile txtstyle "gbenor.shx")
          (vla-put-bigfontfile txtstyle "GBCBIG.shx")
          (vla-put-width txtstyle 1.0)
  (vla-regen acadDocument acActiveViewport)
(defun c:tx (/ acaddocument tstyle textitem textcont seltext i textsel             texti)  (vl-load-com)  (setq acaddocument (vla-get-activedocument (vlax-get-acad-object)))  (setq tstyle (vla-get-textstyles acaddocument))
  (vla-add tstyle "CXB_txt")  (setq textitem (vla-item tstyle "CXB_txt"))  (vla-put-fontfile textitem "gbenor.shx")   (vla-put-bigfontfile textitem "GBCBIG.shx")  (vla-put-width textitem 1)  (vla-put-height textitem 0.0)  (prompt "\n点选需转换的字体:")  (setq seltext (vlax-ename->vla-object (car (entsel))))  (setq selstyle (vla-get-stylename seltext))  (setq        textsel         (ssget "_x" (list (cons 0 "TEXT,ATTDEF") (cons 7 selstyle)))  )  (setq i 0)  (repeat (sslength textsel)    (setq texti (vlax-ename->vla-object (ssname textsel i)))    (vla-put-stylename texti "CXB_txt")    (vla-put-scalefactor texti 1)    (setq i (1+ i))  )  (vla-regen acadDocument acActiveViewport)  (princ))
试试这个
nx 这个不可取,它会把原图纸采用的字体给i替换,要把没有字库得字体替代即可了。  发表于 2019-9-5 17:00
发表于 2012-11-5 14:07:49 | 显示全部楼层
K版,你的是不是有点问题,提示未知命令,是不是哪里多了一个括号?
自行测试下,好久没去弄这个了...  发表于 2012-11-5 14:52
发表于 2012-11-6 12:53:33 | 显示全部楼层
能不能解释一下程序的原理?
GMT+8, 2025-7-16 04:20 , Processed in 0.176807 second(s), 30 queries , Gzip On.
