查看: 4463|回复: 16
请求一个简单DCL对话框的lisp代码
发表于 2011-12-15 18:35:33 | 显示全部楼层 |阅读模式
挂了一个CAD外挂,但图标太多,想用一个image_button对话框集中调用一些功能,每个image_button对应外挂的一个命令。我是菜鸟,写不了lisp代码调用命令,恳请高手编一个。
已知DCL的fil1至fil6 对应 fil1_sld至fil6_sld,相对应的外挂命令是yx_yt、yx_roo、yx_dfx、yx_dad、yx_sg、yx_4mi。
外挂安装在d:\cad下
DCL对话框:
dcl_settings : default_dcl_settings{audit_level = 0;}
ima_but:image_button{width=16;aspect_ratio=0.6;color=152;}
fil:dialog{label="常用功能";
:row{
:ima_but{key="fil1";}
:ima_but{key="fil2";}
:ima_but{key="fil3";}
:row{
:ima_but{key="fil4";}
:ima_but{key="fil5";}
:ima_but{key="fil6";}
:row{fixed_width=true; alignment=centered;
cancel_button;
发表于 2011-12-17 09:09:39 | 显示全部楼层
  1. (defun c:tt ()
  2. (if (> (setq dcl_id (load_dialog (findfile "fil.dcl"))) 0) (progn
  3.   (if (new_dialog "fil" dcl_id "") (progn
  4.    (showsld)
  5.    (action_tile "fil1" "(done_dialog 1)")
  6.    (action_tile "fil2" "(done_dialog 2)")
  7.    (action_tile "fil3" "(done_dialog 3)")
  8.    (action_tile "fil4" "(done_dialog 4)")
  9.    (action_tile "fil5" "(done_dialog 5)")
  10.    (action_tile "fil6" "(done_dialog 6)")
  11.    (action_tile "cancel" "(done_dialog 0)")
  12.    (setq re (start_dialog))
  13.   )
  14.    (princ "\n无法显示对话框!")
  15.   )
  16.   (unload_dialog dcl_id)
  17. )
  18.   (princ "\n无法加载对话框!")
  19. )
  20. (cond
  21.   ((= re 1) (load "d:/cad/yx_yt") (c:yx_yt))
  22.   ((= re 2) (load "d:/cad/yx_roo") (c:yx_roo))
  23.   ((= re 3) (load "d:/cad/yx_dfx") (c:yx_dfx))
  24.   ((= re 4) (load "d:/cad/yx_dad") (c:yx_dad))
  25.   ((= re 5) (load "d:/cad/yx_sg") (c:yx_sg))
  26.   ((= re 6) (load "d:/cad/yx_4mi") (c:yx_4mi))
  27. )
  28. (princ)
  29. )
  30. ;已知DCL的fil1至fil6 对应 fil1_sld至fil6_sld
  31. (defun showsld ()
  32. (setq sldname "fil" i 1)
  33. (repeat 6
  34.   (setq sldnm (strcat sldname (itoa i))
  35.         x (dimx_tile sldnm)
  36.         y (dimy_tile sldnm))
  37.   (if (setq sld (findfile (strcat sldnm "_sld.sld"))) (progn
  38.    (start_image sldnm)
  39.    (fill_image 0 0 x y -2)
  40.    (slide_image 0 0 x y sld)
  41.    (end_image)
  42.   )
  43.    (set_tile sldnm (strcat sldnm "_sld.sld"))
  44.   )
  45.   (setq i (1+ i))
  46. )
  47. )
发表于 2022-8-2 11:31:43 | 显示全部楼层
提供一個完整的範例(含幻燈片) 可參考看看
檔案存放路徑 d槽 temp 目錄下
若放在其他地方 則需修改 程式中的 路徑  (setq path "D:\\TEMP\\")
執行指令:tt2
效果如動態圖
 楼主| 发表于 2011-12-17 10:18:17 | 显示全部楼层
感谢大大!
可是为什么我加载输入tt命令对话框一闪就不见了呢???
还有我需要加载sld幻灯片的代码,就是 fil1对 fil1_sld,fil2对 fil2_sld.............
 楼主| 发表于 2011-12-17 14:28:39 | 显示全部楼层
找到问题了,老大的(defun sowsld ()漏了一个字母,应是(defun showsld ()。
可问题是点幻灯片调用不了外挂命令呀。
发表于 2012-2-17 21:24:26 | 显示全部楼层
shousld函数重名了。所以只能有一个程序能正常执行。
发表于 2013-1-29 14:44:19 | 显示全部楼层
可问题是点幻灯片调用不了外挂 ...
为什么不显示名字?只有白色底子
(defun c:tt ()
   (showsld)
   (action_tile "画箭头" "(done_dialog 1)")
(cond
  ((= re 1) (load "D:/soft/工具/画箭头.lsp") (c:hjt))
(defun showsld ()
(repeat 6
        x (dimx_tile sldnm)
   (start_image sldnm)
   (end_image)
  (setq i (1+ i))
ima_but:image_button{width=8;aspect_ratio=0.6;color=255;}
:row{
     :boxed_column{
     fixed_width=true;
     label="图层类";
:ima_but{key="画箭头";}
:row{
cancel_button;
发表于 2023-9-11 22:17:40 | 显示全部楼层
这里就执行不了
再下载一次试试  发表于 2023-9-12 00:07
发表于 2023-9-12 12:15:01 | 显示全部楼层
shcvip 发表于 2023-9-11 22:17
这里就执行不了
程序停在这里了。
发表于 2023-9-12 14:14:35 | 显示全部楼层
GMT+8, 2025-4-19 04:09 , Processed in 0.209915 second(s), 33 queries , Gzip On.
