一个变量都能搞定,
以前刚学LISP的时候弄的,因为本人是从系统变量开始入手的........ - ;修改和设置标注精度 作者:KAIXIN
- (defun c:KJ_BJD ()
- (setvar "cmdecho" 0)
- (PRINC "\n修改和设置当前标注精度")
- (setq dimdec (getvar "DIMDEC") )
- (prompt "\n-->当前标注精度为:(" )(princ dimdec)(princ ") " )
- (setq dimdec (getint "\n-->请输入新值: "))
- (COMMAND "DIMDEC" dimdec)
- (while (setq ss (ssget":s"'((0 . "DIMENSION"))))
- (command "DIM1" "UP" ss "")
- (PRINC "\n所选地方-->修改和设置标注精度完成!")(PRINC))
