查看: 15786|回复: 37
[【风之影】] [源码]动态粗糙度
发表于 2011-12-18 19:16:13 | 显示全部楼层 |阅读模式
只贴出源码,原理详见我以前的帖子http://bbs.mjtd.com/thread-90666-1-1.html
  1. roughness:dialog
  2. {
  3.   label="粗糙度";
  4.   spacer;
  5.   :row
  6.   {
  7.     :column
  8.     {
  9.       :image_button
  10.       {
  11.         key = "RM";
  12.         aspect_ratio = 1;
  13.         width        = 8;
  14.         fixed_width  = true;
  15.         color        = graphics_background;
  16.         allow_accept = true;
  17.       }
  18.       :image_button
  19.       {
  20.         key = "UN";
  21.         aspect_ratio = 1;
  22.         width        = 8;
  23.         fixed_width  = true;
  24.         color        = graphics_background;
  25.         allow_accept = true;
  26.       }
  27.       :image_button
  28.       {
  29.         key = "BS";
  30.         aspect_ratio = 1;
  31.         width        = 8;
  32.         fixed_width  = true;
  33.         color        = graphics_background;
  34.         allow_accept = true;
  35.       }
  36.     }
  37.     :list_box
  38.     {
  39.       key="RV";
  40.       value=8;
  41.       width=16;
  42.       height=14;
  43.       allow_accept=true;
  44.     }
  45.   }
  46.   :errtile
  47.   {
  48.     width=18;
  49.   }
  50.   ok_cancel;
  51. }
  1. (defun c:rough(/ scl value prcs DLG_ID llist
  2.                p1u p2u p3u pcu ptu pqy
  3.                p1d p2d p3d pcd ptd
  4.                ename era erb dra drb
  5.                snappnt nearpnt tag code ang
  6.                max_x max_y do p00 ra rb
  7.               )
  8.   (defun do_list()
  9.     (start_list "RV" 1)
  10.     (setq value (nth (atoi $value) llist))
  11.     (end_list)
  12.     (set_tile "error" (strcat "粗糙度为 Ra" value))
  13.   )
  14.   (defun myerr(msg)
  15.     (command "undo" "e")
  16.     (setvar "osmode" os)
  17.     (entdel ename)
  18.     (setq *error* olderr)
  19.   )
  20.   (setvar "cmdecho" 0)
  21.   (setq os (getvar "osmode"))
  22.   (setq olderr *error*)
  23.   (setq *error* myerr)
  24.   (setvar "osmode" 0)
  25.   (command "undo" "be")
  26.   (setq scl (getvar "dimscale"))
  27.   (setq value "3.2")
  28.   (setq prcs 1)
  29.   (setq DLG_ID (load_dialog "rough.dcl"))
  30.   (new_dialog "roughness" DLG_ID)
  31.   (start_image "RM")
  32.   (setq max_x (dimx_tile "RM") max_y (dimy_tile "RM"))
  33.   (slide_image 5 5 (- max_x 10) (- max_y 10) (strcat (findfile "rough.slb") "(RM)"))
  34.   (end_image)
  35.   (start_image "UN")
  36.   (setq max_x (dimx_tile "UN") max_y (dimy_tile "UN"))
  37.   (slide_image 5 5 (- max_x 10) (- max_y 10) (strcat (findfile "rough.slb") "(UN)"))
  38.   (end_image)
  39.   (start_image "BS")
  40.   (setq max_x (dimx_tile "BS") max_y (dimy_tile "BS"))
  41.   (slide_image 5 5 (- max_x 10) (- max_y 10) (strcat (findfile "rough.slb") "(BS)"))
  42.   (end_image)
  43.   (setq llist '("" "0.025" "0.05" "0.1" "0.2" "0.4" "0.8" "1.6" "3.2" "6.3" "12.5" "25" "50"))
  44.   (start_list "RV")
  45.   (mapcar 'add_list llist)
  46.   (end_list)
  47.   (set_tile "RV" "8")
  48.   (set_tile "error" (strcat "粗糙度为 Ra3.2"))
  49.   (action_tile "RM" "(setq prcs 1)")
  50.   (action_tile "UN" "(setq prcs 2)")
  51.   (action_tile "BS" "(setq prcs 0)")
  52.   (action_tile "RV" "(do_list)")
  53.   (action_tile "accept" "(done_dialog 1)(setq do T)")
  54.   (action_tile "cancel" "(done_dialog 0)")
  55.   (start_dialog)
  56.   (unload_dialog DLG_ID)
  57.   (if do
  58.     (progn
  59.       (setq p00 '(0.0 0.0 0.0))
  60.       (setq p1u '(2.3094 4.0 0.0))
  61.       (setq p2u '(-2.3094 4.0 0.0))
  62.       (setq p3u '(5.7735 10.0 0.0))
  63.       (setq pcu '(0.0 2.67 0.0))
  64.       (setq ptu '(0.0 6.5 0.0))
  65.       (setq p1d '(-2.3094 -4.0 0.0))
  66.       (setq p2d '(2.3094 -4.0 0.0))
  67.       (setq p3d '(-5.7735 -10.0 0.0))
  68.       (setq pcd '(0.0 -2.67 0.0))
  69.       (setq ptd '(0.0 -6.5 0.0))
  70.       (setq pqy '(-12.0 3.0 0.0))
  71.       (create_ra)
  72.       (create_rb)
  73.       (entdel erb)
  74.       (prompt "选择插入点")
  75.       (setq ename era)
  76.       (setq loop T)
  77.       (while loop
  78.         (setq code (grread T 8))
  79.         (cond
  80.           ((= (car code) 5)(do_move))
  81.           ((= (car code) 3)(do_left))
  82.           ((or (= (car code) 11)(= (car code) 25))(do_right))
  83.           ((or (equal code '(2 97))(equal code'(2 65)))(do_a))
  84.           ((or (equal code '(2 115))(equal code'(2 83)))(do_s))
  85.         )
  86.       )
  87.     )
  88.   )
  89.   (setvar "osmode" os)
  90.   (command "undo" "e")
  91.   (setq *error* olderr)
  92.   (princ)
  93. )
  94. (defun do_a()
  95.   (setq value (cadr (member value llist)))
  96.   (if value (progn (refresh ra)(refresh rb))(setq value "50"))
  97. )
  98. (defun do_s()
  99.   (setq value (cadr (member value (reverse llist))))
  100.   (if value (progn (refresh ra)(refresh rb))(setq value ""))
  101. )
  102. (defun refresh(bname / kname edata)
  103.   (tblnext "block" T)
  104.   (while (/= (cdr (assoc 2 (setq kname (tblnext "block")))) bname))
  105.   (setq edata (entget (cdr (assoc -2 kname))))
  106.   (entmod (subst (cons 1 value)(assoc 1 edata) edata))
  107.   (entupd ename)
  108. )
  109. (defun create_ra()
  110.   (entmake (list '(0 . "BLOCK")'(10 0 0 0)'(70 . 1)'(2 . "*U")))
  111.   (entmake (list '(0 . "TEXT")(cons 10 p00)(cons 11 ptu)'(8 . "DIM")'(40 . 2.5)'(62 . 3)'(72 . 4)(cons 1 value)))
  112.   (cond
  113.     ((= prcs 1)(entmake (list '(0 . "LINE")(cons 10 p1u)(cons 11 p2u)'(8 . "DIM"))))
  114.     ((= prcs 2)(entmake (list '(0 . "CIRCLE")(cons 10 pcu)'(40 . 1.33)'(8 . "DIM"))))
  115.   )
  116.   (entmake (list '(0 . "LINE")(cons 10 p00)(cons 11 p2u)'(8 . "DIM")))
  117.   (entmake (list '(0 . "LINE")(cons 10 p00)(cons 11 p3u)'(8 . "DIM")))
  118.   (setq ra (entmake '((0 . "ENDBLK"))))
  119.   (entmake (list '(0 . "INSERT")(cons 10 p00)(cons 41 scl)(cons 42 scl)(cons 2 ra)))
  120.   (setq era (entlast))
  121.   (setq dra (entget era))
  122. )
  123. (defun create_rb()
  124.   (entmake (list '(0 . "BLOCK")'(10 0 0 0)'(70 . 1)'(2 . "*U")))
  125.   (entmake (list '(0 . "TEXT")(cons 10 p00)(cons 11 ptd)'(8 . "DIM")'(40 . 2.5)'(62 . 3)'(72 . 4)(cons 1 value)))
  126.   (cond
  127.     ((= prcs 1)(entmake (list '(0 . "LINE")(cons 10 p1d)(cons 11 p2d)'(8 . "DIM"))))
  128.     ((= prcs 2)(entmake (list '(0 . "CIRCLE")(cons 10 pcd)'(40 . 1.33)'(8 . "DIM"))))
  129.   )
  130.   (entmake (list '(0 . "LINE")(cons 10 p00)(cons 11 p2d)'(8 . "DIM")))
  131.   (entmake (list '(0 . "LINE")(cons 10 p00)(cons 11 p3d)'(8 . "DIM")))
  132.   (setq rb (entmake '((0 . "ENDBLK"))))
  133.   (entmake (list '(0 . "INSERT")(cons 10 p00)(cons 41 scl)(cons 42 scl)(cons 2 rb)))
  134.   (setq erb (entlast))
  135.   (setq drb (entget erb))
  136. )
  137. (defun do_left()
  138.   (setq snappnt (cadr code))
  139.   (entdel ename)
  140.   (if (osnap snappnt "nea")
  141.     (progn
  142.       (entdel ename)
  143.       (create_ra)
  144.       (create_rb)
  145.       (entdel erb)
  146.       (setq ename era)
  147.     )
  148.     (progn
  149.       (entdel ename)
  150.       (setq dra (subst (cons 50 0.0)(assoc 50 dra) dra))
  151.       (setq dra (subst (cons 41 (* 1.25 (cdr (assoc 41 dra))))(assoc 41 dra) dra))
  152.       (setq dra (subst (cons 42 (* 1.25 (cdr (assoc 42 dra))))(assoc 42 dra) dra))
  153.       (entmod dra)
  154.       (entmake (list '(0 . "TEXT")'(8 . "DIM")'(10 0.0 0.0 0.0)(cons 40 (* scl 5.0))'(62 . 3)'(72 . 4)(cons 11 (mapcar '+ (mapcar (function (lambda (x)(* scl x))) pqy) snappnt))'(1 . "其余")))
  155.       (setq loop nil)
  156.     )
  157.   )
  158. )
  159. (defun do_right()
  160.   (setq loop nil)
  161.   (entdel ename)
  162. )
  163. (defun do_move()
  164.   (setq snappnt (cadr code))
  165.   (entdel ename)
  166.   (setq nearpnt (osnap snappnt "nea"))
  167.   (if nearpnt
  168.     (progn
  169.       (setq ang (angle nearpnt snappnt))
  170.       (cond
  171.         (
  172.           (and (>= ang (/ pi 6.0))(<= ang pi))
  173.           (setq ang (- ang (/ pi 2.0)))
  174.           (entdel era)
  175.           (setq ename era)
  176.           (setq dra (subst (cons 10 nearpnt)(assoc 10 dra) dra))
  177.           (setq nearpnt nil)
  178.           (setq dra (subst (cons 50 ang)(assoc 50 dra) dra))
  179.           (entmod dra)
  180.         )
  181.         (
  182.           (or (= ang 0.0)(and (> ang (* (/ pi 6.0) 7.0))(< ang (* pi 2.0))))
  183.           (setq ang (+ ang (/ pi 2.0)))
  184.           (entdel erb)
  185.           (setq ename erb)
  186.           (setq drb (subst (cons 10 nearpnt)(assoc 10 drb) drb))
  187.           (setq nearpnt nil)
  188.           (setq drb (subst (cons 50 ang)(assoc 50 drb) drb))
  189.           (entmod drb)
  190.         )
  191.         (T
  192.           (entdel era)
  193.           (setq ename era)
  194.           (setq nearpnt nil)
  195.         )
  196.       )
  197.     )
  198.     (progn
  199.       (entdel era)
  200.       (setq ename era)
  201.       (setq dra (subst (cons 10 snappnt)(assoc 10 dra) dra))
  202.       (setq dra (subst (cons 50 0.0)(assoc 50 dra) dra))
  203.       (entmod dra)
  204.       (setq nearpnt nil)
  205.     )
  206.   )
  207. )
命令:rough
按a键数值增加,按s键数值减少
参与人数 10明经币 +14 金钱 +15 收起 理由
tigcat + 1 很给力!
muwind + 1
Michael527 + 1 很给力!
yjr111 + 1 很给力!
669423907 + 1
自贡黄明儒 + 1 达到专业软件水平,造福机械行业设计者
仲文玉 + 2 很给力!
ZZXXQQ + 2 + 15 赞一个!
xiaxiang + 2 很给力!
Gu_xl + 2 赞一个!
本帖被以下淘专辑推荐:
发表于 2022-5-27 11:01:10 | 显示全部楼层
这个程序真好用,加入我的工具箱了。修改了一下,把幻灯片和对话框整合到sp里了
;;; *风之影粗糙度绘制,langjs修改
(defun c:ccd (/ $value a ang b bname c code dcl_pt dcl_re dclname do dra drb edata ename era erb f kname llist loop myerr
                nearpnt olderr os p00 p1d p1u p2d p2u p3d p3u pcd pcu pqy prcs ptd ptu ra rb scl snappnt value x
  (defun do_list ()
    (start_list "RV" 1)
    (end_list)
  (defun myerr (msg)
    (entdel ename)
  (defun image (a b c)
    (if (= a 0)
        (start_image "RM")
        (fill_image 0 0 48 48 4)
        (vector_image 20 40 40 5 5)
        (vector_image 20 40 12 26 5)
        (vector_image 28 26 12 26 5)
        (vector_image 20 41 40 6 5)
        (vector_image 20 41 12 27 5)
        (vector_image 28 27 12 27 5)
        (end_image)
        (start_image "RM")
        (fill_image 0 0 48 48 5)
        (vector_image 20 40 40 5 7)
        (vector_image 20 40 12 26 7)
        (vector_image 28 26 12 26 7)
        (vector_image 20 41 40 6 7)
        (vector_image 20 41 12 27 7)
        (vector_image 28 27 12 27 7)
        (end_image)
    (if (= b 0)
        (start_image "UN")
        (vector_image 18 26 23 26 5)
        (vector_image 17 27 18 27 5)
        (vector_image 23 27 24 27 5)
        (vector_image 16 28 17 28 5)
        (vector_image 24 28 25 28 5)
        (vector_image 16 29 16 32 5)
        (vector_image 25 29 25 32 5)
        (vector_image 16 33 17 33 5)
        (vector_image 24 33 25 33 5)
        (vector_image 17 34 18 34 5)
        (vector_image 23 34 24 34 5)
        (vector_image 18 35 23 35 5)
        (end_image)
        (start_image "UN")
        (vector_image 18 26 23 26 7)
        (vector_image 17 27 18 27 7)
        (vector_image 23 27 24 27 7)
        (vector_image 16 28 17 28 7)
        (vector_image 24 28 25 28 7)
        (vector_image 16 29 16 32 7)
        (vector_image 25 29 25 32 7)
        (vector_image 16 33 17 33 7)
        (vector_image 24 33 25 33 7)
        (vector_image 17 34 18 34 7)
        (vector_image 23 34 24 34 7)
        (vector_image 18 35 23 35 7)
        (end_image)
    (if (= c 0)
        (start_image "BS")
        (end_image)
        (start_image "BS")
        (end_image)
  (defun do_a ()
    (if value
        (refresh ra)
        (refresh rb)
      (setq value "50")
  (defun do_s ()
    (if value
        (refresh ra)
        (refresh rb)
      (setq value "")
  (defun refresh (bname / kname edata)
    (tblnext "block" t)
    (entmod (subst
              (cons 1 value)
              (assoc 1 edata)
              edata
    (entupd ename)
  (defun create_ra ()
    (entmake (list '(0 . "BLOCK") '(10 0 0 0) '(70 . 1) '(2 . "*U")))
    (entmake (list '(0 . "TEXT") (cons 10 p00) (cons 11 ptu) (cons 7 (getvar "DIMTXSTY")) '(8 . "DIM") '(40 . 2.5) '
                   (62 . 3) '(72 . 4) (cons 1 value)
    (cond
      ((= prcs 1)
        (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p1u) (cons 11 p2u) '(8 . "DIM")))
      ((= prcs 2)
        (entmake (list '(0 . "CIRCLE") '(62 . 4) (cons 10 pcu) '(40 . 1.33) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p2u) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p3u) '(8 . "DIM")))
    (entmake (list '(0 . "INSERT") (cons 10 p00) (cons 41 scl) (cons 42 scl) (cons 2 ra)))
  (defun create_rb ()
    (entmake (list '(0 . "TEXT") (cons 10 p00) (cons 11 ptd) (cons 7 (getvar "DIMTXSTY")) '(8 . "DIM") '(40 . 2.5) '
    (cond
      ((= prcs 1)
        (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p1d) (cons 11 p2d) '(8 . "DIM")))
      ((= prcs 2)
        (entmake (list '(0 . "CIRCLE") '(62 . 4) (cons 10 pcd) '(40 . 1.33) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p2d) '(8 . "DIM")))
    (entmake (list '(0 . "LINE") '(62 . 4) (cons 10 p00) (cons 11 p3d) '(8 . "DIM")))
    (entmake (list '(0 . "INSERT") (cons 10 p00) (cons 41 scl) (cons 42 scl) (cons 2 rb)))
  (defun do_left ()
    (entdel ename)
        (entdel ename)
        (create_ra)
        (create_rb)
        (entdel erb)
        (setq ename era)
        (entdel ename)
        (setq dra (subst
                    (cons 50 0.0)
                    (assoc 50 dra)
                    dra
        (setq dra (subst
                    (assoc 41 dra)
                    dra
        (setq dra (subst
                    (assoc 42 dra)
                    dra
        (entmod dra)
        (entmake (list '(0 . "TEXT") (cons 7 (getvar "DIMTXSTY")) '(8 . "DIM") '(10 0.0 0.0 0.0) (cons 40 (* scl 4.0))
                       (cons 41 0.8) '(62 . 3) '(72 . 4) (cons 11 (mapcar
        (mapcar
        (* scl x)
        pqy
        snappnt
                                                         ) '(1 . "其余")
        (setq loop nil)
  (defun do_right ()
    (setq loop nil)
    (entdel ename)
  (defun do_move ()
    (entdel ename)
    (if nearpnt
        (cond
          ((and
             (>= ang (/ pi 6.0))
             (<= ang pi)
            (entdel era)
            (setq ename era)
            (setq dra (subst
                        (cons 10 nearpnt)
                        (assoc 10 dra)
                        dra
            (setq nearpnt nil)
            (setq dra (subst
                        (cons 50 ang)
                        (assoc 50 dra)
                        dra
            (entmod dra)
          ((or
             (= ang 0.0)
             (and
               (< ang (* pi 2.0))
            (entdel erb)
            (setq ename erb)
            (setq drb (subst
                        (cons 10 nearpnt)
                        (assoc 10 drb)
                        drb
            (setq nearpnt nil)
            (setq drb (subst
                        (cons 50 ang)
                        (assoc 50 drb)
                        drb
            (entmod drb)
          (t
            (entdel era)
            (setq ename era)
            (setq nearpnt nil)
        (entdel era)
        (setq ename era)
        (setq dra (subst
                    (cons 10 snappnt)
                    (assoc 10 dra)
                    dra
        (setq dra (subst
                    (cons 50 0.0)
                    (assoc 50 dra)
                    dra
        (entmod dra)
        (setq nearpnt nil)
  (vl-load-com)
  (setvar "osmode" 0)
  (setq value "3.2")
  (setq prcs 1)
  (setq dclname (vl-filename-mktemp "rough.dcl")
        f (open dclname "w")
  (write-line "roughness:dialog{ label=\"风之影粗糙度\"; spacer; " f)
  (write-line " :row { :column {  " f)
  (write-line ":image_button { key = \"RM\"; aspect_ratio = 1; width = 8; fixed_width = true; color = graphics_background; allow_accept = true; }"
              f
  (write-line ":image_button { key = \"UN\"; aspect_ratio = 1; width = 8; fixed_width = true; color = graphics_background; allow_accept = true; } "
              f
  (write-line ":image_button { key = \"BS\"; aspect_ratio = 1; width = 8; fixed_width = true; color = graphics_background; allow_accept = true; } } "
              f
  (write-line ":list_box { key=\"RV\"; value=8; width=16; height=14; allow_accept=true; } } " f)
  (write-line ":errtile { width=18; } ok_cancel;}" f)
  (close f)
  (setq dcl_re (load_dialog dclname))
  (new_dialog "roughness" dcl_re "" dcl_pt)
         "0.05" "0.1"
         "0.2" "0.4"
         "0.8" "1.6"
         "3.2" "6.3"
         "12.5" "25"
         "50"
  (start_list "RV")
  (mapcar
    'add_list
    llist
  (end_list)
  (image 0 0 0)
  (set_tile "RV" "8")
  (action_tile "RM" "(image 1 0 0) (setq prcs 1)")
  (action_tile "UN" "(image 0 1 0)  (setq prcs 2)")
  (action_tile "BS" "(image 0 0 1)  (setq prcs 0)")
  (start_dialog)
  (unload_dialog dcl_re)
  (vl-file-delete dclname)
  (if do
      (setq pqy '(-9.0 3.0 0.0))
      (create_ra)
      (create_rb)
      (entdel erb)
      (prompt "\n选择插入点,[A键]增加,[S键]减小:")
      (setq ename era)
      (setq loop t)
      (while loop
        (setq code (grread t 15 0))
        (cond
          ((= (car code) 5)
            (do_move)
          ((= (car code) 3)
            (do_left)
          ((or
             (= (car code) 11)
             (= (car code) 25)
            (do_right)
          ((or
             (equal code' (2 65))
            (do_a)
          ((or
             (equal code' (2 83))
            (do_s)
发表于 2022-5-27 11:24:16 | 显示全部楼层
楼主的工具 总是那么实用  都是精品
 楼主| 发表于 2011-12-19 07:16:11 | 显示全部楼层
程序提前在我的群200499529中共享。
发表于 2011-12-19 07:58:16 | 显示全部楼层
好程序
一个字
很好
发表于 2011-12-19 08:29:40 | 显示全部楼层
支持风之影
群:200499529已满,可加入新超级群62555795
发表于 2011-12-19 10:22:31 | 显示全部楼层
好强劲的风啊!
发表于 2011-12-19 21:27:18 | 显示全部楼层
字高如果能为当前标注样式的字体与字高是不是会更完美些呢?
发表于 2011-12-20 08:43:23 | 显示全部楼层
强,程序很人性化了
发表于 2012-1-5 20:16:08 | 显示全部楼层
      楼主,我加载你的程序经常列死机,不知怎么回事
  抱歉,,不好意思,是因为找不到SLB文件,所以死机
          但如找不到能自动中断就好点,
            谢楼主分享
 楼主| 发表于 2012-1-5 20:19:55 | 显示全部楼层
源码都给你了。别人用都没问题,好好检查一下自己的CAD
发表于 2012-2-9 17:31:11 | 显示全部楼层
一个字
好程序
很好用
GMT+8, 2025-8-12 05:07 , Processed in 0.220671 second(s), 35 queries , Gzip On.
