查看: 2369|回复: 4
如何更改当前标注样式中的文字样式而不生成标注样式替代.
发表于 2011-12-18 19:23:28 | 显示全部楼层 |阅读模式
1.如何更改当前标注样式中的文字样式而不生成标注样式替代.
2.如何删除已有的标注样式替代.
该贴已经同步到 namezg的微博
发表于 2011-12-18 19:31:00 | 显示全部楼层
1.(command "_.DIMSTYLE" "_SAVE")
2.标注样式替代是因为相关系统变量被修改但又为保存到当前样式,当当前样式被修改即不现实样式替代,无需删除也无法删除
发表于 2011-12-18 19:37:56 | 显示全部楼层
标注样式替代是作为扩展数据写入标注图元的,应该可以通过删除图元扩展数据恢复成默认的标注样式。
发表于 2018-1-19 15:30:53 | 显示全部楼层
第一个问题
public static void SetDimStyleCurrent(string DimStyleName)
    // Establish connections to the document and its database
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    // Establish a transaction
    using (Transaction tr = doc.TransactionManager.StartTransaction())
        DimStyleTable dst = (DimStyleTable)tr.GetObject(db.DimStyleTableId, OpenMode.ForRead);
        ObjectId dimId = ObjectId.Null;
        string message = string.Empty;
        if (!dst.Has(DimStyleName))
            CreateModifyDimStyle(DimStyleName, out message);
            dimId = dst[DimStyleName];
        else
        DimStyleTableRecord dstr = (DimStyleTableRecord)tr.GetObject(dimId, OpenMode.ForRead);
        /* NOTE:
         * If this code is used, and the updated style is current,
         * an override is created for that style.
         * This is not what I wanted.
        //if (dstr.ObjectId != db.Dimstyle)
        //    db.Dimstyle = dstr.ObjectId;
        //    db.SetDimstyleData(dstr);
        /* Simply by running these two lines all the time, any overrides to updated dimstyles get
         * cleared away as happens when you select the parent dimstyle in AutoCAD.
        tr.Commit();
关键在于
要两句一起用,我之前也是只用一句,总是有个替代
GMT+8, 2025-5-19 21:52 , Processed in 0.159064 second(s), 26 queries , Gzip On.
