查看: 18224|回复: 40
[【风之影】] [源码]动态标高
发表于 2011-12-20 07:54:28 | 显示全部楼层 |阅读模式
  1. (defun c:bg(/ ename0 InsY Y Y0 loop code ename edata snap near blkdata scl pnt height fname)
  2.   (setvar "CMDECHO" 0)
  3.   (defun myerr(msg)
  4.     (command "undo" "e")
  5.     (if ename (entdel ename))
  6.     (setq *error* olderr)
  7.   )
  8.   (defun create()
  9.     (command "insert" "KUAI" '(0.0 0.0 0.0) scl scl "0" "0.000")
  10.     (setq ename (entlast))
  11.     (setq edata (entget (entnext ename)))
  12.   )
  13.   (defun insert()
  14.     (setvar "DIMZIN" 0)
  15.     (setq pnt0 (getpoint "请选择插入点\n"))
  16.     (setq height (rtos (getreal "请输入基准标高\n") 2 3))
  17.     (setq scl (getvar "dimscale"))
  18.     (command ".insert" fname pnt0 scl scl "0" height)
  19.   )
  20.   (defun do_right()
  21.     (setq loop nil)
  22.     (entdel ename)
  23.   )
  24.   (defun do_move()
  25.     (setq snap (cadr code))
  26.     (entdel ename)
  27.     (setq near (osnap snap "nea"))
  28.     (entdel ename)
  29.     (setq Y (nth 2 (assoc 10 (entget ename))))
  30.     (setq Y (+ (/ (- Y InsY) 1000.0) Y0))
  31.     (if near (setq snap near))
  32.     (entmod (subst (cons 10 snap)(assoc 10 (setq blkdata (entget ename))) blkdata))
  33.     (setq edata (subst (cons 10 (mapcar '+ (list (* scl 2.25)(* scl 3.42) 0.0) snap))(assoc 10 edata) edata))
  34.     (entmod edata)
  35.     (entmod (subst (cons 1 (rtos Y 2 3))(assoc 1 edata) edata))
  36.     (entupd ename)
  37.     (entupd (entnext ename))
  38.   )
  39.   (setq olderr *error*)
  40.   (setq *error* myerr)
  41.   (command "undo" "be")
  42.   (if (or (and (not (tblsearch "block" "KUAI"))(setq fname (findfile "KUAI.dwg")))(not (ssget "x" '((0 . "INSERT")(2 . "KUAI")))))(insert))
  43.   (if (and (setq ename0 (car (entsel "请选择标高基准\n")))(= (cdr (assoc 2 (entget ename0))) "KUAI"))
  44.     (progn
  45.       (setq InsY (nth 2 (assoc 10 (entget ename0))))
  46.       (setq scl (cdr (assoc 41 (entget ename0))))
  47.       (setq Y0 (atof (cdr (assoc 1 (entget (entnext ename0))))))
  48.       (create)
  49.       (setq loop T)
  50.       (while loop
  51.         (setq code (grread T 8))
  52.         (cond
  53.           ((= (car code) 5)(do_move))
  54.           ((= (car code) 3)(create))
  55.           ((or (= (car code) 11)(= (car code) 25))(do_right))
  56.         )
  57.       )
  58.     )
  59.   )
  60.   (command "undo" "e")
  61.   (setq *error* olderr)
  62.   (princ)
  63. )
将KUAI.dwg放到支持目录里,加载bg.lsp
命令:BG
根据命令行提示操作,先选择基准标高。
左键选择,右键退出
虽然用不到,但是能够给用的到的朋友带来很大的效率!  发表于 2011-12-20 08:04
参与人数 8明经币 +8 收起 理由
xgr + 1 好代码,可以用到
vlisp2012 + 1
T_T + 1 赞一个!
yoyoho + 1 赞一个!
yjr111 + 1 很给力!
lrd1861 + 1 赞一个!
xiaxiang + 1 赞一个!
【KAIXIN】 + 1 赞一个!
    共1人打赏
发表于 2023-1-13 15:48:55 | 显示全部楼层
在楼主的基础之上我改写了动态标高的部分内容,可以捕捉点了,标高块会自动生成。
回复 支持 2 反对 0
发表于 2022-4-14 11:54:58 | 显示全部楼层
如果把基准标高镜像后再使用,因为块参照X比例是负数,所以文字和标高是反的。我把源码里的插入的Y方向比例值改为绝对值后,标高符号位置正确了,但是文字显示是反的。查询了属性文字的插入点也已经更新了,不知道这是什么原因。
发表于 2024-11-13 09:00:36 | 显示全部楼层
看看我这个是否符合版主的思路?cass通用升级版CGC圆圈高程(标高Gu_xl)点CFC三角形高程(标高77077)点创建http://bbs.mjtd.com/forum.php?mo ... &fromuid=418631[/url]
发表于 2011-12-20 08:47:58 | 显示全部楼层
这个要顶哦 谢谢共享源码!
发表于 2011-12-20 10:15:09 | 显示全部楼层
好像没反应,
 楼主| 发表于 2011-12-20 10:52:24 来自手机 | 显示全部楼层
键入BG命令后,要先选择原始标高的块。如果不选或选错,程序退出。
发表于 2011-12-20 11:21:30 | 显示全部楼层
觉得楼主再改一下会更好,最好是把块加在程序里,同时加上各种提示; 现在论坛上很多东东都非常不错,只是操作性比较差
此程序是应其它行业的人要求开发的,我本人并不了解该行业的使用习惯,只是看到院长给出的动画后模仿而开发。那些不愿意共享的人肯定不想看到这样的源码。这个比我那个动态粗糙度简单多了,但原理一样。程序已更新。  发表于 2011-12-22 07:54
发表于 2011-12-20 15:45:17 | 显示全部楼层
我觉得海龙工具箱里面的自动标高程序功能很好用
楼主这个加载了没反应
 楼主| 发表于 2011-12-20 23:02:44 | 显示全部楼层
楼主这个加载了没反应
更新,有提示了
发表于 2011-12-22 08:47:42 | 显示全部楼层
用起来好像不是很方便
这里有以前张越写的一个标高程序 http://bbs.mjtd.com/forum.php?mod=viewthread&tid=3960
发表于 2011-12-22 08:56:17 | 显示全部楼层
谢谢楼主分享!
发表于 2011-12-22 10:22:04 | 显示全部楼层
不错,楼主你可以做得更好
GMT+8, 2025-10-16 04:03 , Processed in 0.312479 second(s), 33 queries , Gzip On.
