查看: 1672|回复: 0
为什么一个框就能过滤掉,两个就不能?
发表于 2011-12-22 13:50:23 | 显示全部楼层 |阅读模式
'想把绿色的线组成的框内的块过滤掉,明明程序设置了几个绿色的框都可以,但运行之后一个框时才能过滤掉
'如果俩绿色框就过滤不掉了,整个图纸的块都选择了?   求解释??????????????????
'本思路是取得块的插入点,很小半径做面域;绿色框变面域;然后点变的面域与每个面域做交集,每次做完,交集面积相加,等于原来的2倍(与自己做一次,与包围他的绿色框一次,不存在框套框现象),判断为在绿色框内。
Function binskid(ByVal Point) As Boolean
Dim ent1 As Object
Dim obname As String
'Dim Point As Variant
binskid = True
On Error Resume Next
'''''''''''''''将绿色的撬变为面域
Dim ss_skid As AcadSelectionSet ', ent As AcadEntity
    Dim regionObj As Variant
    Dim dxf_code() As Integer, dxf_value() As Variant
    Dim greenline() As AcadEntity
    Set ss_skid = ThisDrawing.SelectionSets("ssLine1")
   If Err Then Set ss_skid = ThisDrawing.SelectionSets.Add("ssLine1")
   ss_skid.Clear
    ReDim dxf_code(0), dxf_value(0) ' 过滤条件
    dxf_code(0) = 62: dxf_value(0) = 3 '颜色的dfx组码是62,绿色的值是3
    ss_skid.Select acSelectionSetAll, , , dxf_code, dxf_value
   ReDim greenline(ss_skid.Count - 1)
       For intCnt = 0 To ss_skid.Count - 1
      Set greenline(intCnt) = ss_skid.Item(intCnt)
       Next
        Set regionObj = ThisDrawing.ModelSpace.AddRegion(greenline)
'将点变为面域
Dim pRegion As Variant
Dim pobjs(0)    As AcadEntity
Set pobjs(0) = ThisDrawing.ModelSpace.AddCircle(Point, 0.0001)  '将点画圆
   Set pRegion = ThisDrawing.ModelSpace.AddRegion(pobjs)(0)  '将圆设置为面域
kk = 2 * pRegion.Area
'MsgBox pRegion.Area
'MsgBox kk
pobjs(0).Delete ''''''''''''''''圆删除
Dim pRegion1   As AcadEntity
Set pRegion1 = pRegion
'''''''''''''''''''''''''''选择图中所有面域
Dim mian(5)  As AcadEntity
i = 0
For Each ent1 In ThisDrawing.ModelSpace '在模型空间里循环
obname = ent1.ObjectName '提取对象类型
'MsgBox obname
If obname = "AcDbRegion" Then '判断对象是否为面域
Set mian(i) = ent1
'MsgBox mian(i).Area
i = i + 1
End If
     Next
''''''''''''''''''点的面域与每个面域做交易,面积相加,如果面积等于原来两倍,说明在内,否则在外
''''''''''''''''橇的面域在做交集的时候删除了
    summianji = 0
     For j = 0 To i - 1
          pRegion1.Boolean acIntersection, mian(j)
          summianji = summianji + pRegion1.Area
     Next
        If summianji = kk Then binskid = False   'false代表在面内
pRegion1.Delete
End Function
GMT+8, 2025-5-25 17:02 , Processed in 0.154836 second(s), 28 queries , Gzip On.
