查看: 1566|回复: 1
请教大家关于偏移的问题
发表于 2003-8-2 20:18:00 | 显示全部楼层 |阅读模式
我想通过以下代码画一个矩形,然后再偏移一下,总是得到怪怪的结果,请那位大侠帮忙查一下原因,改变矩形四个点的坐标后,有时候却能得到正确的结果,难道offset命令还与源对象的坐标有关?另外我请问一下,要画一个矩形有没有更简捷的命令??
Private Sub Command1_Click()
Dim plineobj As AcadLWPolyline
Dim points(0 To 7) As Double
On Error Resume Next         '以下调用AutoCAD2004
Set CadApp = GetObject(, "AutoCAD.Application")
If Err Then
  Err.Clear
  Set CadApp = CreateObject("AutoCAD.Application")
  If Err Then
    MsgBox Err.Description
    Exit Sub
  End If
End If
CadApp.Application.Visible = True
Set CadDoc = CadApp.ActiveDocument
   points(0) = 2745
   points(1) = 600
   points(2) = 12177
   points(3) = 600
   points(4) = 12177
   points(5) = -1620
   points(6) = 2745
   points(7) = -1620
Set plineobj = CadDoc.ModelSpace.AddLightWeightPolyline(points)
plineobj.Closed = True
plineobj.Offset -60
End Sub
发表于 2003-8-4 13:07:00 | 显示全部楼层
我是了一下没有出现你说的情况。
矩形绘制程序入内
Function AddRectangle(varPnt1 As Variant, varPnt2 As Variant) As AcadLWPolyline
  On Error GoTo Err_Control
  Dim objSpace As AcadBlock
    If ThisDrawing.ActiveSpace = acModelSpace Then
      Set objSpace = ThisDrawing.ModelSpace
    Else
      Set objSpace = ThisDrawing.PaperSpace
    End If
    Dim plineObj As AcadLWPolyline
    points(0) = varPnt1(0): points(1) = varPnt1(1)
    points(2) = varPnt1(0): points(3) = varPnt2(1)
    points(4) = varPnt2(0): points(5) = varPnt2(1)
    points(6) = varPnt2(0): points(7) = varPnt1(1)
    Set plineObj = objSpace.AddLightWeightPolyline(points)
      plineObj.Closed = True
    Set AddRectangle = plineObj
Exit_Here:
  Exit Function
Err_Control:
  Resume Exit_Here
End Function
Sub addrec()
  Dim pnt1 As Variant
  Dim pnt2 As Variant
  pnt1 = ThisDrawing.Utility.GetPoint(, "请输入角点:")
  pnt2 = ThisDrawing.Utility.GetCorner(pnt1, "请输入另一角点:")
  AddRectangle pnt1, pnt2
End Sub
GMT+8, 2025-5-11 01:23 , Processed in 0.182002 second(s), 23 queries , Gzip On.
