查看: 2310|回复: 3
VB关闭指定程序
发表于 2012-1-2 20:11:57 | 显示全部楼层 |阅读模式
Dim procname$, rtn&
Private Sub Command1_Click()
procname = "explorer.exe"
strcomputer = "."
Set objWMIService = GetObject("winmgmts:" & "{impersonationLevel=impersonate}!\\.\root\cimv2")
Set colProcessList = objWMIService.ExecQuery("Select * from Win32_Process Where Name = '" & procname & "'")
If colProcessList.Count = 0 Then
MsgBox procname & " 没有运行"
Else
For Each objProcess In colProcessList
rtn = MsgBox("您确定要终止 " & procname & " 吗?", vbYesNo, "强制关闭进程")
If rtn = 6 Then objProcess.Terminate
Next
End If
End Sub
发表于 2012-1-2 20:57:26 | 显示全部楼层
支持,我到现在没有搞清vb如何转换成lisp在cad中运行
发表于 2012-1-3 13:44:46 | 显示全部楼层
vb是vb.lsp是lsp两者有区别
发表于 2012-1-6 11:03:58 | 显示全部楼层
谢谢分享,这样也可以查询特定程序是否在运行
GMT+8, 2025-5-25 12:43 , Processed in 0.182101 second(s), 24 queries , Gzip On.
