查看: 13900|回复: 28
[【风之影】] [源码]动态的公差基准
发表于 2012-1-3 10:31:59 | 显示全部楼层 |阅读模式
  1. (defun c:DTM(/ os olderr scl obj ename edata ename0 edata0 ename1 edata1 ename2 edata2)
  2.   (vl-load-com)
  3.
  4.   (defun dtmerr(msg)
  5.     (command "undo" "e")
  6.     (setvar "osmode" os)
  7.     (if ename0 (entdel ename0))
  8.     (if ename1 (entdel ename1))
  9.     (if ename2 (entdel ename2))
  10.     (setq *error* olderr)
  11.   )
  12.   (defun createdatum(/ blk)
  13.     (setq ename0 nil)
  14.     (setq ename1 nil)
  15.     (setq ename2 nil)
  16.     (if (setq obj (nentsel))
  17.       (progn
  18.         (setq spnt (cadr obj))
  19.         (setq obj (vlax-ename->vla-object (car obj)))
  20.         (entmake (list '(0 . "BLOCK")(cons 2 "*U")'(70 . 1)'(10 0.0 0.0 0.0)))
  21.         (entmake (list '(0 . "TEXT")'(10 0.0 0.0 0.0)'(11 0.0 0.0 0.0)'(8 . "DIM")'(40 . 3.5)'(62 . 3)'(72 . 4)'(1 . "")))
  22.         (entmake (list '(0 . "CIRCLE")'(8 . "DIM")'(10 0.0 0.0 0.0)'(40 . 3.5)))
  23.         (setq blk (entmake '((0 . "ENDBLK"))))
  24.         (entmake (list '(0 . "INSERT")'(10 0.0 0.0 0.0)(cons 41 scl)(cons 42 scl)(cons 2 blk)))
  25.         (setq ename0 (entlast))
  26.         (setq edata0 (entget ename0))
  27.         (setq ename (entnext (tblobjname "BLOCK" blk)))
  28.         (setq edata (entget ename))
  29.         (entmake (list '(0 . "LINE")'(8 . "DIM")'(10 0.0 1.6 0.0)'(11 0.0 6.5 0.0)))
  30.         (setq ename1 (entlast))
  31.         (setq edata1 (entget ename1))
  32.         (entmake (list '(0 . "LWPOLYLINE")'(8 . "DIM")'(100 . "AcDbEntity")'(100 . "AcDbPolyline")'(90 . 2)'(43 . 0.4)'(10 3.5 1.6 0.0)'(10 -3.5 1.6 0.0)))
  33.         (setq ename2 (entlast))
  34.         (setq edata2 (entget ename2))
  35.       )
  36.     )
  37.   )
  38.
  39.   (defun do_move(/ mpos npnt ang spnt epnt pnt0 pnt1)
  40.     (setq mpos (cadr code))
  41.     (setq npnt (vlax-curve-getClosestPointTo obj mpos T))
  42.
  43.     (setq ang (angle npnt mpos))
  44.     (if (< (distance mpos npnt) (* scl 10.0)) (setq mpos (polar npnt (angle npnt mpos) (* scl 10.0))))
  45.     (setq edata0 (subst (cons 10 mpos) (assoc 10 edata0) edata0))
  46.     (setq spnt (polar npnt ang (* scl 1.6)))
  47.     (setq epnt (polar npnt ang (- (distance mpos npnt)(* scl 3.5))))
  48.     (setq edata1 (subst (cons 10 spnt) (assoc 10 edata1) edata1))
  49.     (setq edata1 (subst (cons 11 epnt) (assoc 11 edata1) edata1))
  50.     (setq pnt0 (polar spnt (+ ang (/ pi 2.0)) (* scl 3.5)))
  51.     (setq pnt1 (polar spnt (- ang (/ pi 2.0)) (* scl 3.5)))
  52.     (setq edata2 (subst (cons 10 pnt0) (assoc 10 edata2) edata2))
  53.     (setq edata2 (subst (cons 10 pnt1) (nth 4 (member (assoc 10 edata2) edata2)) edata2))
  54.     (entmod edata0)
  55.     (entmod edata1)
  56.     (entmod edata2)
  57.     (entupd ename0)
  58.     (entupd ename1)
  59.     (entupd ename2)
  60.   )
  61.   (defun do_datum (/ ref string)
  62.     (setq ref (cadr code))
  63.     (if (or (<= 65 ref 90) (<= 97 ref 122))
  64.       (progn
  65.         (setq string (strcase (chr ref)))
  66.         (setq edata (subst (cons 1 string)(assoc 1 edata) edata))
  67.         (entmod edata)
  68.         (entupd ename)
  69.       )
  70.     )
  71.   )
  72.   (setvar "cmdecho" 0)
  73.   (setq os (getvar "osmode"))
  74.   (setvar "osmode" 0)
  75.   (command "undo" "be")
  76.   (setq olderr *error*)
  77.   (setq *error* dtmerr)
  78.   (setq scl (getvar "dimscale"))
  79.
  80.   (prompt "Please select object:\n")
  81.   (createdatum)
  82.   (setq loop T)
  83.   (while (and obj loop)
  84.     (setq code (grread T 8))
  85.     (cond
  86.       ((= (car code) 5)(do_move))                                ;;;move
  87.       ((= (car code) 3)(createdatum))                            ;;;left-right
  88.       ((or (= (car code) 11)(= (car code) 25))(setq loop nil))   ;;;button-right
  89.       ((= (car code) 2)(do_datum))                               ;;;datum
  90.     )
  91.   )
  92.
  93.   (command "undo" "e")
  94.   (setvar "osmode" os)
  95.   (setq *error* olderr)
  96.   (princ)
  97. )
操作方法:左键选择需要标注公差基准的图元,拖动到合适的位置后左键确定,可连续标注,字母键改变基准标识,右键退出
暂时对块中图元不支持,这个问题在我前几天的帖子http://bbs.mjtd.com/forum.php?mod=viewthread&tid=91567&page=1#pid501705中继续讨论
参与人数 3明经币 +3 收起 理由
寒潮大冬瓜 + 1
jfxia + 1 好用,源码
669423907 + 1 很给力!
发表于 2022-6-5 06:50:12 | 显示全部楼层
风大师你这个程序很好用  对于我们这个行业来说  一个程序拆解一下就好了。分成两个程序
第1个程序  只需要粗一点的那根线  其他全部不要,也不要按一下出现字母的功能 ,程序还是要动态的确定那根线的位置 我们厂里用来标识零件内凹 还是凸起来
第2个程序  只需要垂直的那根线  其他全部不要 ,也不要按一下出现字母的功能 ,程序还是要动态的确定那根线的位置 ,这根线我们厂里用来做零件的引入线
风大师,由于顾虑你没有时间来修改一下,还在编程求助里开了一个求助,如果你有空修改一下是最好了。
发表于 2018-4-22 21:52:34 | 显示全部楼层
冒个烟圈 发表于 2015-5-20 14:36
我跟你出现的问题一样,应该是这句引起的(entmake (list '(0 . "LWPOLYLINE")'(8 . "DIM")'(100 . "AcDbE ...
解决很简单,将最后一个点对列表'(10 -3.5 1.6 0.0)删除即可。
发表于 2022-6-1 21:38:17 | 显示全部楼层
命令: ; 错误: 参数类型错误: numberp: nil     不知道什么原因
 楼主| 发表于 2012-1-3 10:34:56 | 显示全部楼层
这个功能本来可以用grread中的osnap实现,但是我已经用它发了两个动态了,再继续下去就要泛滥成灾,所以用选取图元求最近距离的方法实现。因为对图块的操作出问题,所以发帖讨论块中图元原位复制。目前这个问题还没有完全解决,最佳结果是高飞鸟的程序。
发表于 2012-1-3 12:48:59 | 显示全部楼层
风的杰作,一定要收藏!再来一个倒角标注,那就爽歪歪了!
发表于 2012-1-4 08:20:57 | 显示全部楼层
这个程序如何使用呀?使用时怎么不出现那个基准符号呀?
 楼主| 发表于 2012-1-4 12:04:12 来自手机 | 显示全部楼层
命令为DTM,要按字母键才出现基准字母
发表于 2012-1-4 12:38:11 | 显示全部楼层
太好了~~~~
发表于 2012-1-4 16:33:16 | 显示全部楼层
cabinsummer 发表于 2012-1-4 12:04
命令为DTM,要按字母键才出现基准字母
提个建议:
1.能否在输入A后,以后如不按键则默认B -> C -> D ......
2.能否在运行命令时提供输入基准字母A、B、C ...... 的输入候选框供选择,以后按字母键则按用户输入,不按的话则按建议第一条处理。
3.系统变量dimscale为0时程序运行有问题,提示为“选择对象: 块参照比例 (0.0000) 无效,设为默认值 1.0000。”,必须设置为非0才正常,请楼主检查。
    最后感谢风大侠提供的精彩源码!
发表于 2012-1-5 19:36:04 | 显示全部楼层
  顶一下好用的源码
发表于 2012-5-3 18:26:38 | 显示全部楼层
这个经典,太值得借鉴了! 学习动态的范例。收藏之
发表于 2013-5-18 20:18:38 | 显示全部楼层
好东西 收藏了顶起
GMT+8, 2025-4-24 00:12 , Processed in 0.264023 second(s), 31 queries , Gzip On.
