查看: 1691|回复: 1
关于ssget " c"
发表于 2012-1-10 00:28:51 | 显示全部楼层 |阅读模式
Andyhon 发表于 2011-12-21 10:43
(Defun C:test ()
   (setq ee (entsel "\n选择紫色的圆弧: ")
         ee (car ee)
        pts (acet-geom-object-end-points ee)    ; 获得圆弧两端点
         pa (car  pts)
         pb (cadr pts)
        ssa (ssget "C" pa pa '((0 . "LINE")))
        ssb (ssget "C" pb pb '((0 . "LINE")))
   (princ "\n框选连结区的线: ")
   (setq ss (ssget '((0 . "LINE"))))
   (cond
    ((ssmemb (setq ee (ssname ssa 0)) ss))
    ((ssmemb (setq ee (ssname ssb 0)) ss))
    (T (Alert "状况外!"))
   (acet-geom-object-end-points ee)    ; 获得A和B两点
请教一下以下两句可以把不和圆弧相切的线排除吗?
ssa (ssget "C" pa pa '((0 . "LINE"))) ;ssget只选和圆弧相切的线(还有线过PA点但是和“(setq ee (entsel "\n选择紫色的圆弧: ")不相切
ssb (ssget "C" pb pb '((0 . "LINE")));ssget只选和圆弧相切的线(还有线过Pb点但是和“(setq ee (entsel "\n选择紫色的圆弧: ")不相切
个人认为:只有用IF判断  发表于 2012-1-10 07:59
发表于 2012-1-10 08:17:00 | 显示全部楼层
用while
判断不合格后继续
GMT+8, 2025-5-31 14:39 , Processed in 0.176680 second(s), 29 queries , Gzip On.
