查看: 1847|回复: 1
求助:如何得到spaceID?
发表于 2012-2-18 05:29:45 | 显示全部楼层 |阅读模式
下面Create方法中的spaceId怎么得到?也就是模型空间或图纸空间的id.
谢谢
Annotation.Create Method (Autodesk.AutoCAD.Geometry.Point3d, Autodesk.AutoCAD.DatabaseServices.ObjectId, Autodesk.AutoCAD.DatabaseServices.ObjectId, Autodesk.AutoCAD.DatabaseServices.ObjectId, bool, bool)
Create an annotation style based annotation.
C#
void Create(Autodesk.AutoCAD.Geometry.Point3d position, Autodesk.AutoCAD.DatabaseServices.ObjectId styleId, Autodesk.AutoCAD.DatabaseServices.ObjectId targetId, Autodesk.AutoCAD.DatabaseServices.ObjectId spaceId, bool bIgnoreAutoInsertOffset, bool bRetainMinWidths);
[url=]Parameters[/url]
Parameters
Description
Input position of annotation.
Input id of annotation style.
Input id of annotation target.
Input id of space (e.g. model or paper) to create annotation in.
Input - if true, uses position and ignores Auto-Insert offest values.
Input - if true, annotation graphics retain their original width when text shrinks.
[url=][/url]
发表于 2012-2-18 09:18:20 | 显示全部楼层
public static string ModelSpace
    Autodesk.AutoCAD.DatabaseServices.BlockTableRecord 的成员
public static string PaperSpace
public Autodesk.AutoCAD.DatabaseServices.ObjectId CurrentSpaceId { get; }
    Autodesk.AutoCAD.DatabaseServices.Database 的成员
GMT+8, 2025-8-16 06:39 , Processed in 0.182328 second(s), 25 queries , Gzip On.
