查看: 1576|回复: 3
这样关不了当前层,请指点
发表于 2012-2-29 16:27:58 | 显示全部楼层 |阅读模式
我是这样写的,比如当前层是1层是,关其他的层是可以的,但是关不了1层。(defun c:F0()(command "'layer" "off" "0"  "" )(princ))
(defun c:F1()(command "'layer" "off" "1"  "" )(princ))
(defun c:F2()(command "'layer" "off" "2"  "" )(princ))
如果写成下面这样,关当前层是可以了,但是关其他层又不方便了,要按2次空格键才行。
请问有没有什么好办法,不管是当前层还是其他层,都可以一次关掉吗?
 楼主| 发表于 2012-2-29 16:29:28 | 显示全部楼层
(defun c:F0()(command "'layer" "off" "0" "Y" "" )(princ))
(defun c:F1()(command "'layer" "off" "1" "Y" "" )(princ))
(defun c:F2()(command "'layer" "off" "2" "Y" "" )(princ))
(defun c:F3()(command "'layer" "off" "3" "Y" "" )(princ))
发表于 2012-2-29 16:37:43 | 显示全部楼层
(if (= (getvar "Clayer") "1") ...)
 楼主| 发表于 2012-2-29 17:11:25 | 显示全部楼层
可以了,谢谢Andyhon 了
GMT+8, 2025-9-25 02:42 , Processed in 0.163612 second(s), 25 queries , Gzip On.
