- 积分
- 547
- 明经币
- 个
- 注册时间
- 2009-1-24
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
怎样融合这两个lisp命令为一个?使用交点打断时,自动先打断多段线。即交点打断包含多段线。
1.多段线打断:
;;;选择的pline线在端点处全部断开.
(defun c:bb (/ ss i en) ;_定义命令名 2006/10/14 师兄
(defun bb1 (e / bg ed no p10 pl pl10 plist pltype pt1 pt2)
(defun GETPLVTX (E / ED)
(defun DXF (NO)
(cdr (assoc NO ED))
) ;end defun
(defun GETLWPL (ED / pl pl10)
(while
(setq ED (cdr (member (setq PL10 (assoc 10 ED)) ED)))
(setq PL (cons (cdr PL10) PL))
(reverse PL)
) ;end defun
(defun GETPL (ED / e p10 pl)
(setq E (DXF -1))
(while
(setq E (entnext E))
(if
(setq P10 (cdr (assoc 10 (entget E))))
(setq PL (cons P10 PL))
) ;end if
) ;end while
(reverse PL)
) ;end defun
(setq ED (entget E))
(setq PLTYPE (DXF 0))
(cond
((= "POLYLINE" PLTYPE)
(GETPL ED)
((= "LWPOLYLINE" PLTYPE)
(GETLWPL ED)
;;下边为了适应多个对象,这行注释,并将e作为此函数的参数
;;; (setq e (car (entsel "选择要断开全部端点的多线段? ")))
;(setq pw (cdr (assoc 41 ED)))
;(setvar "plinewid" Pw)
(setq bg T)
(setq plist (GETPLVTX e))
;(command "erase" e "")
(while (or bg (and pt1 pt2))
(if (= bg T)
(setq bg nil)
(progn (command "break" e pt2 "@")
(setq e (entlast))
(setq pt1 (car plist))
(setq plist (cdr plist))
(setq pt2 (car plist))
;;;下边是师兄加的部份
(princ "\n选择要全部断开端点的多段:") ;_提示用户
(setq ss (ssget)) ;_构建选择集 SS
(setq i '0) ;_步进初值 0
(if (= (type ss) 'PICKSET) ;_判断选择集有效性
(repeat (sslength ss) ;_循环选择集中每一个对象
(setq en (ssname ss i) ;_本次循环要处理的图元
i (1+ i) ;_下一图元的选择集索引加1
(bb1 en) ;_运行打断程序
(princ);_静默退出
2.交点打断:
;;;=======================[ BreakObjects.lsp ]==============================
;;; Author: Copyright?2006,2007 Charles Alan Butler
;;; Contact @ www.TheSwamp.org
;;; Version: 1.3 April 9,2007
;;; Globalization by XANADU - www.xanadu.cz
;;; Purpose: Break All selected objects
;;; permitted objects are lines, lwplines, plines, splines,
;;; ellipse, circles & arcs
;;; Function c:BreakAll - Break all objects selected
;;; Function c:BreakwObjects - Break many objects with a single object
;;; Function c:BreakObject - Break a single object with many objects
;;; Function c:BreakWith - Break selected objects with other selected objects
;;; Function c:BreakTouching - Break objects touching the single Break object
;;; Function c:BreakSelected - Break selected objects with any objects that touch it
;;; Sub_Routines:
;;; break_with
;;; ssget->vla-list
;;; list->3pair
;;; onlockedlayer
;;; get_interpts Return a list of intersect points
;;; break_obj Break entity at break points in list
;;; Requirements: objects must have the same z-value
;;; Restrictions: Does not Break objects on locked layers
;;; Returns: none
;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED ;
;;; WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR ;
;;; PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED. ;
;;; You are hereby granted permission to use, copy and modify this ;
;;; software without charge, provided you do so exclusively for ;
;;; your own use or for use by others in your organization in the ;
;;; performance of their normal duties, and provided further that ;
;;; the above copyright notice appears in all copies and both that ;
;;; copyright notice and the limited warranty and restricted rights ;
;;; notice below appear in all supporting documentation. ;
;; M A I N S U B R O U T I N E
;;打断对象,隔断对象,自断
(defun NBTF_break_with (ss2brk ss2brkwith self
/ cmd intpts
lst masterlist ss
ssobjs onlockedlayer
ssget->vla-list list->3pair
get_interpts break_obj
;; ss2brk selection set to break
;; ss2brkwith selection set to use as break points
;; self when true will allow an object to break itself
;; note that plined will break at each vertex
(vl-load-com)
;; S U B F U N C T I O N S
(defun onlockedlayer (ename / entlst)
(setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
(= 4 (logand 4 (cdr (assoc 70 entlst))))
(defun ssget->vla-list (ss / i ename lst)
(setq i -1)
(while (setq ename (ssname ss (setq i (1+ i))))
(setq lst (cons (vlax-ename->vla-object ename) lst))
lst
(defun list->3pair (old / new)
(while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
old (cdddr old)
(reverse new)
;; return a list of intersect points
(defun get_interpts (obj1 obj2 / iplist)
(if (not (vl-catch-all-error-p
(setq
iplist (vl-catch-all-apply
'vlax-safearray->list
(list
(vlax-variant-value
(vla-intersectwith obj1 obj2 acextendnone)
iplist
;; Break entity at break points in list
(defun break_obj (ent brkptlst / brkobjlst
en enttype maxparam closedobj
minparam obj obj2break p1param
p2 p2param
(setq obj2break ent
brkobjlst (list ent)
enttype (cdr (assoc 0 (entget ent)))
(foreach brkpt brkptlst
;; get last entity created via break in case multiple breaks
(if brkobjlst
;; if pt not on object x, switch objects
(if (not (numberp (vl-catch-all-apply
'vlax-curve-getdistatpoint
(list obj2break brkpt)
(foreach obj brkobjlst ; find the one that pt is on
(if (numberp (vl-catch-all-apply
(list obj brkpt)
(setq obj2break obj) ; switch objects
;; Handle any objects that can not be used with the Break Command
;; using one point, gap of 0.000001 is used
(cond
((and (= "SPLINE" enttype) ; only closed splines
(vlax-curve-isclosed obj2break)
(setq p1param (vlax-curve-getparamatpoint obj2break brkpt)
p2 (vlax-curve-getpointatparam
obj2break
(+ p1param 0.000001)
(command "._break"
obj2break
"_non"
(trans brkpt 0 1)
"_non"
(trans p2 0 1)
((= "CIRCLE" enttype) ; break the circle
obj2break
(command "._break"
obj2break
"_non"
(trans brkpt 0 1)
"_non"
(trans p2 0 1)
(setq enttype "ARC")
((and (= "ELLIPSE" enttype) ; only closed ellipse
;; Break the ellipse, code borrowed from Joe Burke 6/6/2005
p2param (+ p1param 0.000001)
minparam (min p1param p2param)
maxparam (max p1param p2param)
obj (vlax-ename->vla-object obj2break)
(vlax-put obj 'startparameter maxparam)
(vlax-put obj 'endparameter (+ minparam (* pi 2)))
(t ; Objects that can be broken
(setq closedobj (vlax-curve-isclosed obj2break))
(command "._break"
obj2break
"_non"
(trans brkpt 0 1)
"_non"
(trans brkpt 0 1)
(if (not closedobj) ; new object was created
(setq brkobjlst (cons (entlast) brkobjlst))
;; S T A R T H E R E
(if (and ss2brk ss2brkwith)
;; CREATE a list of entity & it's break points
(foreach obj (ssget->vla-list ss2brk)
; check each object in ss2brk
(if (not (onlockedlayer (vlax-vla-object->ename obj)))
(setq lst nil)
;; check for break pts with other objects in ss2brkwith
(foreach intobj (ssget->vla-list ss2brkwith)
(if (and (or self (not (equal obj intobj)))
(setq intpts (get_interpts obj intobj))
(setq lst (append (list->3pair intpts) lst))
; entity w/ break points
(if lst
(setq masterlist
(cons (cons (vlax-vla-object->ename obj) lst)
masterlist
;; masterlist = ((ent brkpts)(ent brkpts)...)
(if masterlist
(foreach obj2brk masterlist
(break_obj (car obj2brk) (cdr obj2brk))
;; Break all objects selected
(defun c:breakall (/ cmd ss)
(command "._undo" "_begin")
(setq cmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
;; get objects to break
(prompt "\n选择需要打断的对象: ")
(if (setq ss (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(NBTF_break_with ss ss nil); ss2break ss2breakwith (flag nil = not to break with self)
(setvar "CMDECHO" cmd)
(command "._undo" "_end")
;; E n d O f F i l e I f y o u A r e H e r e
