查看: 2979|回复: 0
求助:帮忙修改一下cad中多段线坐标输出到excel
发表于 2012-3-6 18:42:31 | 显示全部楼层 |阅读模式
选择AutoCAD中的pl线,然后将x和y坐标输出到excel当前激活单元格位置。麻烦高手帮忙改改吧,非常感谢。
我根据网上的代码,修改了一下,可是偶尔可以运行成功。不知道问题出在哪里。
Sub a()
    '连接EXCEL——标准代码****************************
       Dim xlApp As Excel.Application
       Dim xlbook As Excel.Workbook
       Dim xlSheet As Excel.Worksheet
       On Error Resume Next
       Set xlApp = GetObject(, "excel.application")
       If Err <> 0 Then
         Err.Clear
         Set xlApp = CreateObject("excel.application")
         If Err <> 0 Then
           MsgBox "无法启动excel"
           Exit Sub
         End If
       End If
       If ActiveWorkbook.Sheets.Count = 0 Then xlbook = xlApp.Workbooks.Add
       Set xlbook = xlApp.ActiveWorkbook
       Set xlSheet = xlbook.ActiveSheet
        xlApp.Visible = True
        If Err <> 0 Then Err.Clear
    '标准代码结束*****************************************
Dim retCoord() As Double
Dim a As AcadLWPolyline
Dim i As Integer
Dim j As Integer
Dim l As Integer
i = 0
ThisDrawing.Utility.GetEntity a, "Select an object"
    retCoord() = a.Coordinates
On Error GoTo e
Do While CBool(retCoord(i)) <> False
j = ActiveCell.Row  '这个无法返回激活单元格地址
l = ActiveCell.Column
xlSheet.Cells(j + i / 2, l).Value = retCoord(i)
xlSheet.Cells(j + i / 2, l + 1).Value = retCoord(i + 1)
i = i + 2
Loop
e: Exit Sub
j = 0
l = 0
End Sub
GMT+8, 2025-4-30 02:55 , Processed in 0.201880 second(s), 27 queries , Gzip On.
