查看: 1770|回复: 4
我要修改物体到0层并且颜色随块怎么写?
发表于 2012-3-15 17:59:14 | 显示全部楼层 |阅读模式
(defun C:0( )
     (setq se1(ssget))
     (command "change" "si" se1 "p" "la" 0 "")
     (command "change" "si" se1 "p" "C" byblock "")
该贴已经同步到 9701519的微博
发表于 2012-3-15 19:52:42 | 显示全部楼层
发表于 2012-3-15 21:38:35 | 显示全部楼层
(defun C:0( )
     (setq se1(ssget))
     (command "chprop" se1 "" "la" "0" "C" "byblock" "")
 楼主| 发表于 2012-3-15 21:46:15 | 显示全部楼层
非常感谢
发表于 2014-9-20 23:05:02 | 显示全部楼层
非常的感谢!
GMT+8, 2025-7-18 05:25 , Processed in 0.264464 second(s), 27 queries , Gzip On.
