查看: 1483|回复: 0
请教VBA问题
发表于 2012-3-16 11:56:44 | 显示全部楼层 |阅读模式
请教各位老师:
下面代码在运行第二遍时出现致命错误。是为什么?
谢谢!
Sub Example_Select()
    Dim SSetColl As AcadSelectionSets
    Set SSetColl = ThisDrawing.SelectionSets
    Dim ssetObj As AcadSelectionSet
    If SSetColl.Count > 0 Then
        For Each obj In ThisDrawing.SelectionSets
            obj.Delete
        Next 'obj
    End If
    Set ssetObj = SSetColl.Add("SSET")
    Dim mode As Integer
    Dim corner1(0 To 2) As Double
    Dim corner2(0 To 2) As Double
    mode = acSelectionSetCrossing
    corner1(0) = 10: corner1(1) = 286: corner1(2) = 0
    corner2(0) = 94: corner2(1) = 291: corner2(2) = 0
    ssetObj.Select mode, corner1, corner2
    Dim txt As AcadEntity
    Dim tx As AcadMText
    For Each txt In ssetObj
    If txt.ObjectName = "AcDbMText" Or txt.ObjectName = "AcDbText" Then
       Debug.Print txt.ObjectName & "内容" & txt.TextString
    End If
    Next
End Sub
GMT+8, 2025-4-30 03:12 , Processed in 0.225242 second(s), 24 queries , Gzip On.
