查看: 3633|回复: 5
block insert both with button & preview of sld
发表于 2012-3-24 21:27:18 | 显示全部楼层 |阅读模式
Dear All,
very urgent please help me
该贴已经同步到 sachindkini的微博
 楼主| 发表于 2012-3-26 16:14:17 | 显示全部楼层
ANY PEOPLE HELP ME
发表于 2012-3-26 16:35:45 | 显示全部楼层
参考下面这个http://web2.airmail.net/terrycad/AutoLISP-Code.htm
Block Library has been revised to be compatible with AutoCAD 2008. The dialogs with slide images have been redesigned and enlarged to accommodate space for longer block names. Block Library is an AutoLISP utility for managing blocks by storing blocks and block slides images in Block Libraries. The block slide images can be quickly viewed in the Block Libraries before inserting them into a drawing. Blk_Lib requires functions inside of GetIcon.lsp.
发表于 2012-3-26 19:55:41 | 显示全部楼层
AutoCad design center is better and standard.
 楼主| 发表于 2012-3-27 02:52:57 | 显示全部楼层
dear sir
thx for reply
better option is design center is true,
but im study the autolisp code because i want sample code of this image
 楼主| 发表于 2012-3-27 03:15:05 | 显示全部楼层
dear sir,
see code but only add please sld file for preview
  1. (defun c:vblk ( / block id name )    (cond        (   (<= (setq id (load_dialog "vblk.dcl")) 0)            (princ "\nDCL File not found.")        )        (   (not (new_dialog "valveblk" id))            (princ "\nDialog could not be loaded.")        )        (   t            (foreach tile '("GATEV" "GLOBE" "BALL" "BUTTERFLY" "CHECK" "PLUG" "WAFER" "NEEDLE" "GLOBE-CV")                (action_tile tile "(setq name $key) (done_dialog)")            )            (start_dialog)            (if name                (if                    (or                        (tblsearch "BLOCK" (setq block name))                        (setq block (findfile (strcat name ".dwg")))                    )                    (command "_.-insert" block "_S" 1.0 "_R" 0.0 pause)                    (princ (strcat "\nBlock: " name ".dwg could not be found."))                )                (princ "\n*Cancel*")            )        )    )    (if (< 0 id) (unload_dialog id))    (princ))
  1. bt : button { width = 15; height = 2; fixed_width = true; fixed_height = true; }valveblk : dialog { label = "Select block to insert"; spacer;    : boxed_column { label = "Valves";        : row {            : column {                : bt { key = "GATEV"; label  ="GATE" ; }                : bt { key = "GLOBE"; label  ="GLOBE"; }                : bt { key = "BALL" ; label = "BALL" ; }                : bt { key = "BUTTERFLY" ; label = "B/FLY"; }            }            : column {                : bt { key = "CHECK"; label = "CHECK"; }                : bt { key = "PLUG" ; label = "PLUG" ; }                : bt { key = "WAFER"; label = "WAFER"; }                : bt { key = "NEEDLE"; label = "NEEDLE"; }            }        }        spacer;    }    : boxed_column { label = "Control Valves";         : bt { key = "GLOBE-CV"; label = "GLOBE CV"; } spacer;    }    : bt { key = "accept"; label = "Cancel"; is_default = true; is_cancel = true; alignment = centered; }}
GMT+8, 2025-12-8 04:58 , Processed in 0.212204 second(s), 30 queries , Gzip On.
