查看: 2407|回复: 5
1如何按图层统计交点个数
发表于 2012-3-29 22:50:11 | 显示全部楼层 |阅读模式
如截图所描述,能到到按图层直线来统计交点个数吗?
 楼主| 发表于 2012-3-31 19:31:00 | 显示全部楼层
大家帮帮忙或者提供个好的思路,感激不尽!
发表于 2012-4-3 13:57:05 来自手机 | 显示全部楼层
应该统计某个层的线与某个层图元交点个数更好
发表于 2012-4-17 19:28:19 | 显示全部楼层
  1. ;;交点列表[ss-选择集]
  2. (defun yad_inters(ss / n n1 obj1 n2 obj2 ipt l_pt)
  3.   (setq        n (sslength ss)
  4.         n1 0
  5.   )
  6.   (while (< n1 (1- n))
  7.     (setq obj1 (vlax-ename->vla-object (ssname ss n1))
  8.           n2 (1+ n1)
  9.     )
  10.     (while (< n2 n)
  11.       (setq obj2 (vlax-ename->vla-object (ssname ss n2))
  12.             ipt  (vlax-variant-value (vla-intersectwith obj1 obj2 0))
  13.       )
  14.       (if (> (vlax-safearray-get-u-bound ipt 1) 0)
  15.         (progn
  16.           (setq ipt (vlax-safearray->list ipt))
  17.           (while (> (length ipt) 0)
  18.             (setq l_pt (cons (list (car ipt) (cadr ipt) (caddr ipt)) l_pt) ipt (cdddr ipt))
  19.           )
  20.         )
  21.       )
  22.       (setq n2 (1+ n2))
  23.     )
  24.     (setq n1 (1+ n1))
  25.   )
  26.   l_pt
  27. )
发表于 2012-4-17 19:29:00 | 显示全部楼层
  1. ;计算曲线交点  功能:返回两个对象的所有交点
  2. ;(KX-get-e1e2jiao en1 en2)  参数: ent1、ent2 均为ename对象
  3. (defun KX-get-jiaodian (en1 en2 / pl pts)
  4.   (setq pl  (vlax-invoke (vlax-ename->vla-object en2) 'IntersectWith (vlax-ename->vla-object en1) acExtendNone))
  5.   (while pl
  6.     (setq pts (append pts (list (list (car pl) (cadr pl) (caddr pl))))
  7.    pl (cdr (cdr (cdr pl)))
  8.    )
  9.     )
  10. pts
  11.   )
发表于 2012-5-10 22:51:47 | 显示全部楼层
【KAIXIN】 发表于 2012-4-17 19:28
交点坐标集请问是不是1_pt???
GMT+8, 2025-4-30 13:42 , Processed in 0.193723 second(s), 28 queries , Gzip On.
