- 积分
- 34940
- 明经币
- 个
- 注册时间
- 2011-6-4
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2012-4-7 20:38:11
显示全部楼层
下面是acad2006.lsp文档内容,请看看什么丢失了?
- ; MODULE_ID ACAD2006_LSP_
- ;;; ACAD2006.LSP Version 1.0 for AutoCAD 2006
- ;;; Copyright (C) 1994-2005 by Autodesk, Inc.
- ;;; Permission to use, copy, modify, and distribute this software
- ;;; for any purpose and without fee is hereby granted, provided
- ;;; that the above copyright notice appears in all copies and
- ;;; that both that copyright notice and the limited warranty and
- ;;; restricted rights notice below appear in all supporting
- ;;; documentation.
- ;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
- ;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
- ;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
- ;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
- ;;; UNINTERRUPTED OR ERROR FREE.
- ;;; Use, duplication, or disclosure by the U.S. Government is subject to
- ;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
- ;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
- ;;; (Rights in Technical Data and Computer Software), as applicable.
- ;;; Note:
- ;;; This file is normally loaded only once per AutoCAD session.
- ;;; If you wish to have LISP code loaded into every document,
- ;;; you should add your code to acaddoc.lsp.
- ;;; Globalization Note:
- ;;; We do not support autoloading applications by the native
- ;;; language command call (e.g. with the leading underscore
- ;;; mechanism.)
- (if (not (= (substr (ver) 1 11) "Visual LISP")) (load "acad2006doc.lsp"))
- ;; Silent load.
- (princ)
复制代码
