查看: 1509|回复: 0
源码出现错误,知道的帮忙改下!
发表于 2012-4-11 10:00:28 | 显示全部楼层 |阅读模式
(defun c:tt ()
(setvar "cmdecho" 0)
(setq txt_str (getstring "\n输入字符前缀"))
(setq txt_h (getreal "\n输入字符高度"))
(setq rec_sget nil)
(setq i 0)
(setq flst (list))
(while (setq pt (getpoint "\n选择内部点"))
  (command "_bpoly" pt "")
  (setq rec (entlast))
  (redraw rec 3)
  (setq rec_sget (ssadd rec))
  (setq pt1 (cdr (nth 14 (entget rec))))
  (setq pt2 (cdr (nth 18 (entget rec))))
  (setq pt3 (cdr (nth 22 (entget rec))))
  (setq pt4 (cdr (nth 26 (entget rec))))
  (setq L (car (mapcar '- pt1 pt2))
        W (cadr (mapcar '- pt2 pt3))
        zx (inters pt1 pt3 pt2 pt4))
  (entdel (entlast))
  (if (setq fk (assoc (list L W) flst))
   (setq flst (subst (cons (list L W) (setq k (1+ (cdr fk)))) fk flst))
   (setq flst (cons (cons (list L W) 1) flst) k 1)
  (command "text" "j" "mc" zx txt_h 0 (strcat txt_str "-" (itoa i) "-" (itoa k)))
  (setq i (1+ i))
  (print L)
  (print W)
GMT+8, 2025-9-25 05:53 , Processed in 0.190816 second(s), 25 queries , Gzip On.
