查看: 4011|回复: 7
两个打断程序
发表于 2012-4-12 09:05:55 | 显示全部楼层 |阅读模式
奉献两个打断程序。一直线打断一组线。这个好办,一个循环就完成了。另一个是一组线打断一根直线。这个有点麻烦,因为断第一点以后,原来的目标变成了两个,那么原来的变量名就不能再用,程序无法继续。经过观察,找到解决办法,请各位行家大力斧正。为提高操作速度,我特意分成两个程序,只要记住两个程序名就可以节省了操作过程中的选项。
1. 一断多:
(defun c:bpm (/ pt )
  (vl-load-com)
  (setvar "cmdecho" 0)
  (setvar "orthomode" 0)
  (setq bl (car (entsel "\nCHOOSE A LINE TO BE CUT:")))
  (setq bl-v (vlax-ename->vla-object bl))
  (prompt "\nCHOOSE CUTTING LINES:")
  (setq cutln-s(ssget '((0 . "LINE,ARC,CIRCLE,ELLIPSE,LWPOLYLINE,SPLINE"))))
  (setq m 0)
  (setq n 0)
( while (< m (sslength cutln-s))
    (setq cutln  (ssname cutln-s m))
    (setq cutln-v (vlax-ename->vla-object cutln))
       (if (and (setq point-v (vla-intersectwith bl-v cutln-v acExtendNone))
        (setq point (vlax-variant-value point-v))
        (> (vlax-safearray-get-u-bound point 1) 0)
         (setq point (vlax-safearray->list (vlax-variant-value point-v)))
         (COMMAND "_break" cutln point "@")
          ;(setq pt(append pt (list point)))
         (setq m (+ m 1))
        )   ; end progn
         (setq m (+ m 1))
        )   ; end if
)          ; end while
2. 多断一。
(defun c:bps (/ pt )
  (vl-load-com)
  (setq cutln-s(ssget '((0 . "LINE,ARC,CIRCLE,ELLIPSE,LWPOLYLINE,SPLINE,INSERT"))))
  (setq m 0)
  (setq n 0)
              (if (> (length point) 3)
                (setq i 0)
                  (repeat (/ (length point) 3)
                    (setq point-i(list (nth i point) (nth (+ i 1) point) (nth (+ i 2) point)))
                    (setq pt(append pt (list point-i)))
                    (setq i (+ i 3))
                  )   ; end repeat
                 )    ; end progn
              )       ; end if >
         (setq m (+ m 1))
        )   ; end progn
         (setq m (+ m 1))
        )   ; end if
)          ; end while
  (setq blst(vlax-curve-getstartpoint bl-v)
        blend(vlax-curve-getendpoint bl-v))
  (if (= (cadr blst) (cadr blend))
       (if (> (car blst) (car blend))
         (setq pt
            (vl-sort pt
              (function (lambda (e1 e2) (> (car e1) (car e2))))
          (setq pt
             (vl-sort pt
               (function (lambda (e1 e2) (< (car e1) (car e2))))
        ) ; end if (>
      )   ; end progn
  (if (> (cadr blst) (cadr blend))
     (setq pt
          (vl-sort pt
            (function (lambda (e1 e2) (> (cadr e1) (cadr e2))))
      (setq pt
           (vl-sort pt
             (function (lambda (e1 e2) (< (cadr e1) (cadr e2))))
   )  ; end progn
)    ; end (=
  (command "_break" bl (nth 0 pt) "@")
  (vl-remove (nth 0 pt) pt)
  (foreach x pt
     (command "_break" (entlast) "non" x "@")
发表于 2012-4-12 09:33:47 | 显示全部楼层
1、可以用SSGET ”F“的方式选择与直线相交的线,再分别在每根线与直线交点处打断;
2、可以求出直线与一组线的所有交点,再把直线起点、终点加上去,再排序,重新生成每段小直线。
 楼主| 发表于 2012-4-12 10:03:06 | 显示全部楼层
2、可以求出直线与一组 ...
谢谢。
我仅仅根据我自己的情况设计的。因为我的图比较密集,极少需要断所有交线,所以我设计成自选目标。原来的初稿还复杂一些,但只要选一根直线,所有和他碰过的都能断开。
发表于 2012-4-12 10:15:56 | 显示全部楼层
自选也可以,也可以增加过滤值
发表于 2012-5-12 14:48:13 | 显示全部楼层
一断多有一个问题,就是不能打断封闭的圆、多边形、矩形、椭圆等,望修改
谢谢楼主的代码
发表于 2012-5-12 19:35:17 | 显示全部楼层
留个脚印先。谢谢楼主分享!
发表于 2012-5-14 15:51:40 | 显示全部楼层
留个脚印先。谢谢楼主分享!
发表于 2015-12-4 00:33:37 | 显示全部楼层
可以求出直线与一组线的所有交点,再把直线起点、终点加上去,再排序,重新生成每段小直线。现在也用到了这个思路
GMT+8, 2025-5-21 00:46 , Processed in 0.165887 second(s), 29 queries , Gzip On.
