查看: 24844|回复: 132
全部明经币求一个求交点个数统计完美程序
发表于 2012-4-30 12:41:36 | 显示全部楼层 |阅读模式
1明经币
:各种颜色的线与柱层墙层交点个数有几个...并输出EXL
最佳答案
查看完整内容
嗯,你说的也有道理,如果图比杂乱还是选择比较好 **** 本内容被作者隐藏 ****
你兜里空了,拿什么悬赏?  发表于 2012-4-30 23:04
发表于 2012-4-30 12:41:37 | 显示全部楼层
(defun c:aa (/ ch co color e1 e2 ent ent1 file_id file_idx i j la la1 lst lst1 name name1 pt0 pt1 pt2 pt3 pt4 r ss ss1 x)
  (setvar "cmdecho" 0)
  (setq name (car (entsel "\n指定线所在图层:"))
        la (assoc 8 (entget name))
        lst1 '()
        ss1 (ssadd)
  (princ (strcat " <" (cdr la) ">"))
  (redraw name 3)
  (setq ss1 (ssadd name ss1))
  (princ "\n选择与线相交的样本:")
  (setvar "nomutt" 1)
  (while (setq name1 (car (entsel)))
    (if (and
          name1
          (setq la1 (assoc 8 (entget name1)))
          (not (equal la la1))
          (not (member (cdr la1) lst1))
        (princ (strcat " <" (cdr la1) ">"))
        (setq lst1 (cons (cdr la1) lst1))
        (redraw name1 3)
        (setq ss1 (ssadd name1 ss1))
  (repeat (setq i (sslength ss1))
    (redraw (ssname ss1 (setq i (1- i))) 4)
  (princ "\n框选计算范围:")
  (setq ss (ssget (list '(0 . "LINE,ARC") la))
        color '((1 . "红线") (2 . "黄线")
         (3 . "绿线")
         (4 . "青线")
         (5 . "蓝线")
         (6 . "洋红线")
         (7 . "白线")
        lst '()
  (setvar "nomutt" 0)
  (repeat (setq i (sslength ss))
    (setq name (ssname ss (setq i (1- i)))
          ent (entget name)
    (if (= (cdr (assoc 0 ent)) "LINE")
      (setq pt1 (cdr (assoc 10 ent))
            pt2 (cdr (assoc 11 ent))
      (setq pt0 (cdr (assoc 10 ent))
            r (cdr (assoc 40 ent))
            pt1 (polar pt0 (cdr (assoc 50 ent)) r)
            pt2 (polar pt0 (cdr (assoc 51 ent)) r)
    (setq pt3 (polar pt1 (angle pt1 pt2) (+ (distance pt1 pt2) 10))
          pt4 (polar pt2 (angle pt2 pt1) (+ (distance pt2 pt1) 10))
    (if (not (assoc 62 ent))
      (setq co (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 ent))))))
      (setq co (cdr (assoc 62 ent)))
    (setq co (cdr (assoc co color)))
    (setq ss1 (ssget "F" (list pt3 pt4)))
    (if (ssmemb name ss1)
      (setq ss1 (ssdel name ss1))
    (repeat (setq j (sslength ss1))
      (setq name1 (ssname ss1 (setq j (1- j))))
      (setq ent1 (entget name1)
            la1 (cdr (assoc 8 ent1))
            ch (strcat co "与" la1 "层交点")
      (if (member la1 lst1)
          (if (/= (cdr la) la1)
            (if (assoc ch lst)
              (setq lst (subst
                          (cons ch (1+ (cdr (assoc ch lst))))
                          (assoc ch lst)
                          lst
              (setq lst (cons (cons ch 1) lst))
  (setq lst (vl-sort lst '(lambda (e1 e2)
                            (< (car e1) (car e2))
  (setq file_idx (getfiled "指定输出文件路径" "" "xls" 1)
        file_id (open file_idx "w")
  (foreach x lst
    (write-line (strcat (car x) "\t" (itoa (cdr x)) "\t" "个") file_id)
    (princ (strcat "\n " (car x) " " (itoa (cdr x)) " " "个"))
  (close file_id)
参与人数 2明经币 +1 金钱 +10 收起 理由
flytoday02 + 10 很给力!
flytoday + 1 很给力!谢谢大师了..
发表于 2012-4-30 12:55:04 | 显示全部楼层
照说还得补上 *.Xls 共构成完整的调试附件
发表于 2012-4-30 13:05:27 | 显示全部楼层
发表于 2012-4-30 13:40:00 | 显示全部楼层
用軸線...就可以有交点......
发表于 2012-4-30 15:46:10 | 显示全部楼层
kkk3kkk 发表于 2012-4-30 13:40
用軸線...就可以有交点......
这个可能只有高手中滴高手能解
顶起.
发表于 2012-4-30 22:40:42 | 显示全部楼层
不怕做不到,就怕想不到
源码在这里
(defun c:aa (/ ch co color e1 e2 ent ent1 file_id file_idx i j la la1 lst name name1 pt0 pt1 pt2 pt3 pt4 r ss ss1 x)
  (setq name (car (entsel "\n选择样本取得图层:")))
  (setq la (assoc 8 (entget name)))
  (princ (strcat " < " (cdr la) " > "))
  (redraw name 3)
         (3 . "绿线")
         (4 . "青线")
         (5 . "蓝线")
         (6 . "洋红线")
         (7 . "白线")
        lst '()
  (redraw name 4)
          ent (entget name)
            ent1 (entget name1)
        (if (assoc ch lst)
          (setq lst (subst
                      (assoc ch lst)
                      lst
  (foreach x lst
  (close file_id)
flytoday + 1 很给力!老师是不是还缺那个延伸回缩程序啊
发表于 2012-4-30 22:58:44 | 显示全部楼层
langjs 发表于 2012-4-30 22:40
不怕做不到,就怕想不到
langjs 老师那个交点是这样子算的哈
能不改成这样..就是先指定样本图层..分别指定..样本图层.线.柱.墙....这三个样本图层后再选择对象..
老师你这个程序..只指定一个样本图层后就好象选择...
选择样本取得图层: < 墙 >
选择对象: 指定对角点: 找到 0 个
选择对象: 指定对角点: 找到 0 个,总计 0 个
选择对象:
; 错误: 参数类型错误: lselsetp nil
但是如果先选择线..好象会对.
框选所有的线是程序必须的  发表于 2012-4-30 23:10
这个程序操作是:现选一条线,取得图层名,再框选所有的线,程序计算与之相交的交点数量……  发表于 2012-4-30 23:05
发表于 2012-4-30 23:03:53 | 显示全部楼层
我先选择指定线层..墙柱层是默认的啊..不是指定的哦老师
发表于 2012-4-30 23:13:42 | 显示全部楼层
能不改成这样..就是先指定样本图层..分别指定..样本图层.线.柱.墙 ...
那老师..我也想指定下墙.柱层啊..这样更好
程序计算的准确性多加实例认证,我小范围认证还可以,大规模靠你自己了,不要数量统计错误就不好了  发表于 2012-5-1 00:12
延伸回缩功能不缺,(setq pt3 (polar pt1 (angle pt1 pt2) (+ (distance pt1 pt2) 10)))计算坐标点坐标时候加了10,只是图形上没变而已。  发表于 2012-5-1 00:07
GMT+8, 2025-5-19 02:28 , Processed in 0.221451 second(s), 30 queries , Gzip On.
