查看: 2340|回复: 4
CAD2009以上有选项卡,如何加载局部菜单中的选项卡?
发表于 2012-5-1 22:25:11 | 显示全部楼层 |阅读模式
在局部菜单中已经定义了选项卡,但加载后在CAD中仍然无法显示,是需要一个命令来激活吗?
该贴已经同步到 NetBee的微博
 楼主| 发表于 2012-5-2 20:52:37 | 显示全部楼层
貌似.net才行呀。
  1. 1- Using VS2005 for AutoCAD 2009:
  2. -- In stdafx.h add this lines:
  3. #using <mscorlib.dll>
  4. #using <System.dll>
  5. #using <acdbmgd.dll>
  6. #using <acmgd.dll>
  7. #using <AcRibbon.dll>
  8. #using <AdWindows.dll>
  9. #using <PresentationCore.dll>
  10. #using <PresentationFramework.dll>
  11. #using <WindowsBase.dll>
  12. --- MyRibbonTabProxy.h
  13. #pragma once
  14. #include "StdAfx.h"
  15. using namespace System;
  16. using namespace Autodesk::Windows;
  17. using namespace Autodesk::AutoCAD::Ribbon;
  18. void MakeIt(void);
  19. public __gc class MyRibbonTabProxy
  20. {
  21. private:
  22.   RibbonTab*  m_RibTab;
  23. public:
  24.   MyRibbonTabProxy(String* title, String* id );
  25. protected:
  26.   void OnButtonClick(Object* sender, Windows::RoutedEventArgs * ea);
  27. };
  28. --- MyRibbonTabProxy.cpp
  29. #include "StdAfx.h"
  30. #include "MyRibbonTabProxy.h"
  31. void MakeIt()
  32. {
  33. MyRibbonTabProxy* rb = new MyRibbonTabProxy( S"CadOfiTec", S"CadOfiTecTab" );
  34. }
  35. MyRibbonTabProxy::MyRibbonTabProxy(String* title, String* id )
  36. {
  37. RibbonControl* ribCtrl = Autodesk::AutoCAD::Ribbon::RibbonServices::RibbonPaletteSet->RibbonControl;
  38. if( ribCtrl == NULL )
  39.   return;
  40. m_RibTab =  ribCtrl->FindTab( id );
  41. if( m_RibTab != NULL )
  42.   return;
  43. m_RibTab = new RibbonTab();
  44. m_RibTab->Title = title;
  45. m_RibTab->Id = id;
  46. ribCtrl->Tabs->Add( m_RibTab );
  47. m_RibTab->IsActive = true;
  48. // Create the panel source
  49. RibbonPanelSource* ribSourcePanel = new RibbonPanelSource();
  50. ribSourcePanel->Title = "Bloques";
  51. RibbonPanel* ribPanel = new RibbonPanel;
  52. ribPanel->Source = ribSourcePanel;
  53. m_RibTab->Panels->Add( ribPanel );
  54. // Create a button
  55. RibbonButton* ribButton1 = new RibbonButton();
  56. ribButton1->Text = S"AddTE";
  57. ribButton1->Click += new Windows::RoutedEventHandler(this, &MyRibbonTabProxy:: OnAddTEClick);
  58. ribButton1->ShowText = true;
  59. RibbonRow* row = new RibbonRow();
  60. row->Items->Add(ribButton1);
  61. ribSourcePanel->Rows->Add( row );
  62. }
  63. void MyRibbonTabProxy:: OnAddTEClick(Object* sender, Windows::RoutedEventArgs *ea)
  64. {
  65. Autodesk::AutoCAD::ApplicationServices::Application:: DocumentManager
  66.   ->MdiActiveDocument->SendStringToExecute(S"_AddTE ",false, false, false );
  67. }
  68. 2 - Using VS2008 for AutoCAD 2011:
  69. -- In stdafx.h add this lines:
  70. #using <mscorlib.dll>
  71. #using <System.dll>
  72. #using <acdbmgd.dll>
  73. #using <acmgd.dll>
  74. #using <AcCui.dll>
  75. #using <AdWindows.dll>
  76. #using <PresentationCore.dll>
  77. #using <PresentationFramework.dll>
  78. #using <WindowsBase.dll>
  79. #pragma once
  80. #include "StdAfx.h"
  81. using namespace System;
  82. using namespace Autodesk::Windows;
  83. void MakeIt(void);
  84. // The new implementation uses ICommand instead RoutedEventHandler
  85. public __gc class AutoCADCommandHandler: public ICommand
  86. {
  87. public:
  88. void remove_CanExecuteChanged(System::EventHandler* eh){};
  89. void add_CanExecuteChanged(System::EventHandler* eh){};
  90. AutoCADCommandHandler(){};
  91. bool CanExecute(Object* parameter);
  92. void Execute(Object* parameter);
  93. };
  94. public __gc class MyRibbonTabProxy
  95. {
  96. private:
  97.   RibbonTab*  m_RibTab;
  98. public:
  99.   MyRibbonTabProxy(String* title, String* id );
  100. };
  101. void MakeIt()
  102. {
  103. MyRibbonTabProxy* rb = new MyRibbonTabProxy( S"CadOfiTec", S"CadOfiTecTab" );
  104. }
  105. bool AutoCADCommandHandler::CanExecute(Object* parameter)
  106. {
  107. return true;
  108. }
  109. void AutoCADCommandHandler::Execute(Object* parameter)
  110. {
  111. RibbonButton* ribBtn =
  112.   static_cast<Autodesk::Windows::RibbonButton*> (parameter);
  113. Autodesk::AutoCAD::ApplicationServices::Application:: DocumentManager
  114.   ->MdiActiveDocument->SendStringToExecute(
  115.   static_cast<System:tring*>(ribBtn->CommandParameter), false, false, false );
  116. }
  117. MyRibbonTabProxy::MyRibbonTabProxy(String* title, String* id )
  118. {
  119. RibbonControl* ribCtrl = Autodesk::Windows::ComponentManager::Ribbon;
  120. if( ribCtrl == NULL )
  121.   return;
  122. m_RibTab =  ribCtrl->FindTab( id );
  123. if( m_RibTab != NULL )
  124.   return;
  125. m_RibTab = new RibbonTab();
  126. m_RibTab->Title = title;
  127. m_RibTab->Id = id;
  128. ribCtrl->Tabs->Add( m_RibTab );
  129. m_RibTab->IsActive = true;
  130. // Create the panel source
  131. RibbonPanelSource* ribSourcePanel = new RibbonPanelSource();
  132. ribSourcePanel->Title = "Bloques";
  133. RibbonPanel* ribPanel = new RibbonPanel;
  134. ribPanel->Source = ribSourcePanel;
  135. m_RibTab->Panels->Add( ribPanel );
  136. // Create a button
  137. RibbonButton* ribButton1 = new RibbonButton();
  138. ribButton1->Text = S"AddTE";
  139. ribButton1->ShowText = true;
  140. AutoCADCommandHandler* ch = new AutoCADCommandHandler();
  141. ribButton1->CommandHandler = ch;
  142. ribSourcePanel->Items->Add( ribButton1 );
  143. }
不知vla-GetInterfaceObject 能否搞定。
发表于 2012-5-2 07:53:21 | 显示全部楼层
CUI命令,选择一个左上角界面方案,点击右侧的自定义工作空间按钮
然后找到自己想显示的选项卡,打勾,再点右上角的完成,依次对各个方案分别操作,最后点确定
 楼主| 发表于 2012-5-2 10:19:32 | 显示全部楼层
呵,主要是需要用程序实现。
发表于 2023-5-20 05:00:59 | 显示全部楼层
NetBee 发表于 2012-5-2 20:52
貌似.net才行呀。不知vla-GetInterfaceObject 能否搞定。
怎么使用?
GMT+8, 2025-11-29 12:39 , Processed in 0.199528 second(s), 31 queries , Gzip On.
