- 积分
- 3950
- 明经币
- 个
- 注册时间
- 2008-9-27
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
1明经币
选择一堆图形,自动求得其“左下角” 经常在实用程序中用到,比如自动坐标标注 (三个视图默认左下角为坐标的0点),这是就要用到,今天写一个 模拟 :"ctrl +shift +v” 建立一个图块,(也以左下角为基点,但是以“图层名+视图位置编号”为块名) 可是人家的ctrl +shift +v就是速度快,几万个数据点,也看不出假死现象,我写了三种方法,速度都慢,现把三种方法贴上,希望大家讨论,并给出最好的程序,最快求得“左下角” 坐标??
注:选择对象不含 "CENTER" "ARC" "HATCH" "TEXT" "MTEXT" "ATTDEF"
法一:求点集list ,对点表 按 x排序,取最小x ,对电表按照 y排序取 最小y ,最终求得 左下角(x y)
- (defun data_num (xx lstSel_xx / data_xx)
- (setq data_xx nil)
- (setq lstSel_xx (member (assoc xx lstSel_xx) lstSel_xx))
- (while lstSel_xx
- (setq data_xx (cons (cdr (car lstSel_xx)) data_xx))
- (setq
- lstSel_xx (member (assoc xx (cdr lstSel_xx)) (cdr lstSel_xx))
- data_xx
- (defun sub_getdata
- (objSel / data data10 data11
- ssIndex objLen objCur lstSel objtype
- entCur
- (vl-load-com)
- (setq data nil)
- (setq ssIndex 0)
- (setq objLen (sslength objSel))
- (repeat objLen
- (setq objCur (ssname objSel ssIndex))
- (setq lstSel (entget objCur))
- (setq objtype (cdr (assoc '6 lstSel)))
- (setq entCur (cdr (assoc '0 lstSel)))
- (if (and (/= objtype "CENTER")
- (/= entCur "ARC")
- (/= entCur "HATCH")
- (/= entCur "TEXT")
- (/= entCur "MTEXT")
- (/= entcur "ATTDEF")
- (progn
- (setq data10 (data_num 10 lstsel))
- (setq data11 (data_num 11 lstsel))
- (setq data (append (append data10 data11) data))
- (setq ssIndex (+ ssIndex 1))
- (setq data (vl-remove nil data))
- (defun sub_minx (data_xsrt / datax e1 e2 minx)
- (vl-load-com)
- (setq datax
- (vl-sort data_xsrt
- (function (lambda (e1 e2) (< (car e1) (car e2))))
- (setq minx (car (car datax)))
- (defun sub_miny (data_ysrt / datay e3 e4 miny)
- (vl-load-com)
- (setq datay
- (vl-sort data_ysrt
- (function (lambda (e3 e4) (< (cadr e3) (cadr e4))))
- (setq miny (cadr (car datay)))
- (defun c:t1
- (/ oldOsm oldCmdecho selset t0 ssdata ssminx ssminy wd_bpnt)
- (setq oldOsm (getvar "OSMODE"))
- (setq oldCmdecho (getvar "CMDECHO"))
- (setvar "OSMODE" 0)
- (setvar "CMDECHO" 0)
- (setq selset (ssget))
- (if selset
- (progn
- (setq t0 (getvar "TDUSRTIMER"))
- (setq ssdata (sub_getdata selset))
- (setq ssminx (sub_minx ssdata))
- (setq ssminy (sub_miny ssdata))
- (setq wd_bpnt (list ssminx ssminy))
- (princ (* (- (getvar "TDUSRTIMER") t0) 86400))
- (princ "秒,最小x,y是:")
- wd_bpnt
法二:用vla-GetBoundingBox 求点表 在对点表求最小(x y)
- (defun get_all_rectang (/ ss pt_list sn n en pt1 pt2)
- (setq ss (ssget "p"
- '((-4 . "<not")
- (0 . "LEADER,CENTER,ARC,HATCH,TEXT,MTEXT,ATTDEF")
- (-4 . "not>")
- (setq pt_list '())
- (setq sn (sslength ss))
- (setq n -1)
- (repeat sn
- (setq en (ssname ss (setq n (1+ n))))
- (vla-GetBoundingBox (vlax-ename->vla-object en) 'pt1 'pt2)
- (setq pt_list (cons (vlax-safearray->list pt1) pt_list))
- ;;(setq pt_list (cons (vlax-safearray->list pt2) pt_list))
- (setq pt1 (apply 'mapcar (cons 'min pt_list)))
- (defun c:t2
- (/ oldOsm oldCmdecho selset t0 wd_bpnt)
- (if selset
- (progn
- (setq wd_bpnt (get_all_rectang))
- wd_bpnt
法三:用 ET工具里求极限点的函数 (ACET-GEOM-SS-EXTENTS SS t)
- (defun c:t3 (/ oldOsm oldCmdecho selset t0 wd_bpnt)
- (if selset
- (progn
- (setq
- ss (ssget "p"
- '((-4 . "<not")
- (-4 . "not>")
- (setq wd_bpnt (car (ACET-GEOM-SS-EXTENTS SS t)))
- wd_bpnt
对下图运算后:
时间如下:
命令: t1
选择对象: 指定对角点: 找到 14400 个
选择对象:
44.235秒,最小x,y是:(-384.388 -172.718)
命令:
命令: t2
选择对象:
1.672秒,最小x,y是:(-384.388 -172.718 0.0)
命令:
命令: t3
选择对象:
4.156秒,最小x,y是:(-384.388 -172.718 0.0)
命令
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
查看完整内容
其中对et函数(ACET-GEOM-SS-EXTENTS SS t)
不解,内部不知道什么算法。用时居然超过 t2 方法
注明:不知道各位运算时间怎样,与配置是否有关 我电脑的配置
电脑型号 技嘉 GA-880G-UD3H 台式电脑
操作系统 Windows XP 专业版 32位 SP3 ( DirectX 9.0c )
处理器 AMD Athlon(速龙) II X4 640 四核
主板 技嘉 GA-880G-UD3H (AMD 760G/780G/780V/785G/790GX/880G/890GX)
