- 积分
- 2465
- 明经币
- 个
- 注册时间
- 2008-4-29
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
 - ;;;=======================[ BreakObjects.lsp ]==============================
- ;; M A I N S U B R O U T I N E
- (defun break_with (ss2brk ss2brkwith self / cmd intpts lst masterlist ss ssobjs
- onlockedlayer ssget->vla-list list->3pair
- get_interpts break_obj
- ;; ss2brk selection set to break
- ;; ss2brkwith selection set to use as break points
- ;; self when true will allow an object to break itself
- ;; note that plined will break at each vertex
- (vl-load-com)
- ;; S U B F U N C T I O N S
- (defun onlockedlayer (ename / entlst)
- (setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
- (= 4 (logand 4 (cdr (assoc 70 entlst))))
- (defun ssget->vla-list (ss / i ename lst)
- (setq i -1)
- (while (setq ename (ssname ss (setq i (1+ i))))
- (setq lst (cons (vlax-ename->vla-object ename) lst))
- lst
- (defun list->3pair (old / new)
- (while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
- old (cdddr old))
- (reverse new)
- ;; return a list of intersect points
- (defun get_interpts (obj1 obj2 / iplist)
- (if (not (vl-catch-all-error-p
- (setq iplist (vl-catch-all-apply
- 'vlax-safearray->list
- (list
- (vlax-variant-value
- (vla-intersectwith obj1 obj2 acextendnone)
- iplist
- ;; Break entity at break points in list
- (defun break_obj (ent brkptlst / brkobjlst en enttype maxparam closedobj
- minparam obj obj2break p1param p2 p2param
- (setq obj2break ent
- brkobjlst (list ent)
- enttype (cdr (assoc 0 (entget ent)))
- (foreach brkpt brkptlst ; get last entity created via break
- ; in case multiple breaks
- (if brkobjlst
- (progn ; if pt not on object x, switch
- ; objects
- (if (not (numberp (vl-catch-all-apply 'vlax-curve-getdistatpoint
- (list obj2break brkpt)
- (foreach obj brkobjlst ; find the one that pt is on
- (if (numberp (vl-catch-all-apply 'vlax-curve-getdistatpoint
- (list obj brkpt)
- (setq obj2break obj) ; switch objects
- ) ; handle any objects that can not
- ; be used with the break command
- ; using one point, gap of 0.000001
- ; is used
- (cond
- ((and
- (= "SPLINE" enttype) ; only closed splines
- (vlax-curve-isclosed obj2break)
- (setq p1param (vlax-curve-getparamatpoint obj2break brkpt)
- p2 (vlax-curve-getpointatparam obj2break (+ p1param 0.000001))
- (command "._break" obj2break "_non" (trans brkpt 0 1) "_non"
- (trans p2 0 1)
- ((= "CIRCLE" enttype) ; break the circle
- (trans p2 0 1)
- (setq enttype "ARC")
- ((and
- (= "ELLIPSE" enttype) ; only closed ellipse
- ) ; break the ellipse, code borrowed
- ; from joe burke 6/6/2005
- p2param (+ p1param 0.000001)
- minparam (min
- p1param
- p2param
- maxparam (max
- p1param
- p2param
- obj (vlax-ename->vla-object obj2break)
- (vlax-put obj 'startparameter maxparam)
- (vlax-put obj 'endparameter (+ minparam (* pi 2)))
- (t ; objects that can be broken
- (setq closedobj (vlax-curve-isclosed obj2break))
- (trans brkpt 0 1)
- (if (not closedobj) ; new object was created
- (setq brkobjlst (cons (entlast) brkobjlst))
- ;; S T A R T H E R E
- (if (and ss2brk ss2brkwith)
- (progn
- ;; CREATE a list of entity & it's break points
- (foreach obj (ssget->vla-list ss2brk) ; check each object in ss2brk
- (if (not (onlockedlayer (vlax-vla-object->ename obj)))
- (progn
- (setq lst nil)
- ;; check for break pts with other objects in ss2brkwith
- (foreach intobj (ssget->vla-list ss2brkwith)
- (if (and (or self (not (equal obj intobj)))
- (setq intpts (get_interpts obj intobj))
- (setq lst (append (list->3pair intpts) lst)) ; entity w/ break points
- (if lst
- (setq masterlist (cons (cons (vlax-vla-object->ename obj) lst) masterlist))
- ;; masterlist = ((ent brkpts)(ent brkpts)...)
- (if masterlist
- (foreach obj2brk masterlist
- (break_obj (car obj2brk) (cdr obj2brk))
- (princ)
- ;; Break all objects selected
- (defun c:breakall (/ cmd ss)
- (command ".undo" "begin")
- (setq cmd (getvar "CMDECHO"))
- (setvar "CMDECHO" 0)
- ;; get objects to break
- (prompt "\nSelect All objects to break & press enter: ")
- (if (setq ss (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
- (Break_with ss ss nil) ; ss2break ss2breakwith (flag nil = not to break with self)
- (setvar "CMDECHO" cmd)
- (command ".undo" "end")
- (princ)
- ;; Break a single object with many objects
- (defun c:BreakObject (/ cmd ss1 ss2)
- (prompt "\nSelect single object to break: ")
- (if (and (setq ss1 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
- (not (redraw (ssname ss1 0) 3))
- (not (prompt "\n*** Select object(s) to break with & press enter: ***"))
- (setq ss2 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
- (not (redraw (ssname ss1 0) 4)))
- (Break_with ss1 ss2 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
- (princ)
- ;; Break many objects with a single object
- (defun c:breakwobjects (/ cmd ss1 ss2)
- (defun ssredraw (ss mode / i num)
- (setq i -1)
- (redraw (ssname ss i) mode)
- (prompt "\nSelect object(s) to break & press enter: ")
- (if (and (setq ss1 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
- (not (ssredraw ss1 3))
- (not (prompt "\n*** Select single object to break with: ***"))
- (setq ss2 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
- (not (ssredraw ss1 4))
- (break_with ss1 ss2 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
- (princ)
- ;; Break many objects with many object
- (defun c:BreakWith (/ cmd ss1 ss2)
- (setq i -1)
- (princ)
- ;; Break many objects with a selected objects
- ;; Selected Objects create ss to be broken
- (defun c:BreakTouching (/ cmd ss1 ss2)
- ;; get all objects touching entities in the sscross
- ;; limited obj types to "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"
- (defun gettouching (sscros / ss lst lstb lstc objl)
- (and
- (setq lstb (vl-remove-if 'listp (mapcar 'cadr (ssnamex sscros)))
- objl (mapcar 'vlax-ename->vla-object lstb)
- (setq
- ss (ssget "_A" (list (cons 0 "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")
- (cons 410 (getvar "ctab"))))
- (setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
- (setq lst (mapcar 'vlax-ename->vla-object lst))
- (mapcar
- '(lambda (x)
- (mapcar
- '(lambda (y)
- (if (not
- (vl-catch-all-error-p
- (vl-catch-all-apply
- '(lambda ()
- (vlax-safearray->list
- (vla-intersectwith y x acextendnone)
- (setq lstc (cons (vlax-vla-object->ename x) lstc))
- ) objl)
- ) lst)
- lstc
- (setq ss1 (ssadd))
- (if (and (not (prompt "\nSelect object(s) to break with & press enter: "))
- (mapcar '(lambda (x) (ssadd x ss1)) (gettouching ss2))
- (princ)
- ;; Break selected objects with any objects that touch it
- (defun c:BreakSelected (/ cmd ss1 ss2)
- (and
- (setq
- (mapcar
- '(lambda (x)
- (mapcar
- '(lambda (y)
- (if (not
- '(lambda ()
- ) objl)
- ) lst)
- lstc
- (break_with ss2 ss1 nil) ; ss2break ss2breakwith (flag nil = not to break with self)
- (princ)
