查看: 3198|回复: 9
为什么不能在对话框image上显示图形?
发表于 2012-5-26 16:08:44 | 显示全部楼层 |阅读模式
(defun c:dwgpre()
      (vl-load-com)
      (setq dwgfiles '(" "))
      (show_dlg)
);end defun c:dwgpre
(defun show_dlg()
      (if (null (setq dcl_id (load_dialog "d:\\shit\\image_dcl")))
  (alert "failed in loading dialog")
  (exit)
   );end progn
      );end if-load dialog
      (new_dialog "img_pre" dcl_id)
      (action_tile "path_sel" "(getf_dwg) (showlist \"dwg_list\")");选择文件夹
      (action_tile "dwg_list" "(getl_data $value)");获取列表框选择数据
      (action_tile "image_pre" "(setq slnm \"dwg_preview \")")
      (action_tile "btn_pre" "(done_dialog 1)");预览
      (action_tile "btn_exit" "(done_dialog 2)");退出
      (setq zhqtask (start_dialog))
      (cond
     ((= zhqtask 1)(dwg_preview));用户操作
     ((= zhqtask 2)(tmp_del))
     (t (princ));
      );end if
);end defun show_dialog
(defun getfolder(/ WinShell shFolder catchit)
  (setq winshell (vlax-create-object "Shell.Application"))
  (setq    shFolder (vlax-invoke-method WinShell 'BrowseForFolder 0 "选择文件夹" 1))
  (setq    catchit (vl-catch-all-apply  '(lambda ()
                (setq shFolder (vlax-get-property shFolder 'self))
                (setq path (vlax-get-property shFolder 'path))
  (if (vl-catch-all-error-p catchit)      nil      path  )
);end defun
(defun getf_dwg()
      (if (getfolder)
   (setq dwgfiles (vl-directory-files path "*.dwg" 1))
  (alert "没有选择文件夹")
  (exit)
      );end if
);end defun get_dwg
(defun showlist(lkey);列表填充函数
      (start_list lkey)
      (mapcar 'add_list dwgfiles)
      (end_list)
);end showlist
(defun getl_data(str);get list_box data
      (setq dwgpath (strcat path "/" (nth (atoi str) dwgfiles)))
);end dwg_pre
(defun dwg_preview()
      (princ dwgpath);
);end defun dwg_preview
(command "mslide" dwg_preview)
(defun show_sld (/ sldnm width heigth)
   (start_image "image_pre");开始处理图像对象
          (setq width (dimx_tile "image_pre"))
   (setq height (dimy_tile "image_pre"))
          (fill_image 0 0 width heigth -3);填充
   (slide_image 0 0 width heigth sldnm);展示幻灯片
   (end_image);结束处理图像对象
(defun tmp_del();退出时删除临时文件
      (princ "delete sld files and then exit")
该贴已经同步到 澷歩澐鍴的微博
发表于 2012-5-26 22:50:27 | 显示全部楼层
这行是干什么的?
发表于 2012-5-27 01:34:15 | 显示全部楼层
楼主是想实现生成幻灯片,供对话框预览,
请确定(command "mslide" dwg_preview)是否是在对话框加载之前生成,
程序太乱,又缺少对话框文件,不能测试。
 楼主| 发表于 2012-5-27 08:08:17 | 显示全部楼层
ZZXXQQ 发表于 2012-5-26 22:50
这行是干什么的?
我想把dwg文件转化为幻灯片格式,再在对话框上预览
 楼主| 发表于 2012-5-27 08:11:01 | 显示全部楼层
xgr 发表于 2012-5-27 01:34
楼主是想实现生成幻灯片,供对话框预览,
请确定(command "mslide" dwg_preview)是否是在对话框加载之前生 ...
img_pre:dialog
        label="图形预览对话框";
        :row
                :boxed_column
                        :image{key="image_pre";width=100;}
                :boxed_column
                        :button{label="选择文件夹";key="path_sel";}
                        :list_box{label="图形文件名称";key="dwg_list";fixed_width_font=true;}
                        :row
                                :button{label="预览";key="btn_pre";}
                                :button{label="退出";key="btn_exit";}
                                cancel_button;
这是对话框文件,请多多指教!
发表于 2012-5-27 08:44:38 | 显示全部楼层
用DosLib吧,很简单就能做到。
dos_dwgpreview显示图形文件的列表及它们的缩略预览图的对话框. 这个函数在选择打开图形和插入块时很有用.
语法
(dos_dwgpreview title path [T])
(dos_dwgpreview title path-list [T])
参数
title
对话框标题.
path
指定路径. 如果指定nil则使用当前路径.
path-list
包含图形文件完整路径的列表.
T
在黑与白之间切换预览图的默认背景色.
返回 选择文件的完整路径.
nil 取消或出错时.
示例
Command: (dos_dwgpreview "Preview a drawing" "c:\\program files\\autocad 2002\\sample")
"c:\\program files\\autocad 2002\\sample\\1st floor architectural.dwg"
根据CAD的版本可以选择DosLib的版本。
 楼主| 发表于 2012-5-28 16:37:11 | 显示全部楼层
xgr 发表于 2012-5-27 08:44
用DosLib吧,很简单就能做到。
dos_dwgpreview显示图形文件的列表及它们的缩略预览图的对话框. 这个函数在 ...
能用autolisp程序做到吗?
发表于 2012-5-28 21:01:23 | 显示全部楼层
这只能生成当前打开的DWG文件的幻灯片啊。
 楼主| 发表于 2012-5-29 05:59:41 | 显示全部楼层
但是驱动对话框后只能将当前文件制作成幻灯片,而不能在对话框上显示出来,这是为什么?
发表于 2012-5-29 07:59:50 | 显示全部楼层
  1. (defun c:slide_show (/ dcl_id q1)
  2.   (vl-load-com)
  3.   (command "mslide" "c:\\slide_image")
  4.   (setq dcl_id (load_dialog "ABCD.dcl"))
  5.   (setq q1 (new_dialog "slide_show" dcl_id))
  6.   (start_image "s1")
  7.   (fill_image 0 0 (dimx_tile "s1") (dimy_tile "s1") 0)
  8.   (slide_image 0 0 (dimx_tile "s1") (dimy_tile "s1") "c:\\slide_image.sld")
  9.   (end_image)
  10.   (action_tile "cancel" "(done_dialog)(exit)")
  11.   (action_tile "accept" "(done_dialog)")
  12.   (start_dialog)
  13.   (unload_dialog dcl_id)
  14.   (vl-file-delete "c:\\slide_image.sld")
  15. )
显示当前文件为幻灯片
DCL文件
  1. slide_show:dialog {
  2.     label = "幻灯片显示";
  3.     :image {
  4.         width = 100;
  5.         height = 30;
  6.         key = "s1";
  7.         }
  8.     ok_cancel ;
  9.     }
GMT+8, 2025-9-25 11:03 , Processed in 0.162426 second(s), 26 queries , Gzip On.
