查看: 6878|回复: 18
怎样把TEXT文字转换成ATTDEF定义的属性
发表于 2012-6-2 16:33:17 | 显示全部楼层 |阅读模式
怎样把TEXT文字转换成ATTDEF定义的属性.明经上有把那属性转换成单字,这就是那相反的功能。最好是集合那功能。互相转换
发表于 2012-6-4 09:28:46 | 显示全部楼层
忘记在哪里找到的,一起分享下,
祝愿所有找LSP的朋友,都能得到答案!
回复 支持 1 反对 1
发表于 2022-12-8 11:24:20 | 显示全部楼层
试试这个
  1. (DEFUN C:TXT2ATT (/ SS1 N TXTENT AA A1 A73 LST_210 LST_10)
  2.   (VL-CMDF "_.undo" "_group")
  3.   (SETVAR "blipmode" 0)
  4.   (PRINC "\n选择TEXT文本对象: ")
  5.   (setq SS1 (SSGET '((0 . "TEXT"))))
  6.   (VL-CMDF "_.UCS" "W")
  7.   (setq N 0)
  8.   (REPEAT (SSLENGTH SS1)
  9.     (setq TXTENT (SSNAME SS1 N))
  10.     (setq LST_210 (APPEND LST_210 (LIST (ASSOC 210 (ENTGET TXTENT)))))
  11.     (setq LST_10 (APPEND LST_10 (LIST (ASSOC 10 (ENTGET TXTENT)))))
  12.     (setq AA (MEMBER '(100 . "AcDbEntity") (ENTGET TXTENT)))
  13.     (setq A73 (CDR (ASSOC 73 AA)))
  14.     (setq A1 (CDR (ASSOC 1 AA)))
  15.     (ENTMAKE
  16.       (APPEND '((0 . "ATTDEF"))
  17.               (REVERSE (CDDR (REVERSE AA)))
  18.               '((100 . "AcDbAttributeDefinition") (70 . 8))
  19.               (LIST (CONS 74 A73) (CONS 3 A1) (CONS 2 A1))
  20.       )
  21.     )
  22.     (setq N (1+ N))
  23.   )
  24.   (VL-CMDF "_.erase" SS1 "")
  25.   (VL-CMDF "_.UCS" "P")
  26. )
发表于 2012-6-4 15:24:59 | 显示全部楼层
  1. (defun ATTDEFtoTEXT(elist / ename fawn);;属性转文本
  2. ;; (ai_undo_push)
  3.   (setq ename(cdr(assoc -1 elist)))
  4.   (entdel ename)
  5.   (setq fawn(assoc 74 elist))
  6.   (setq elist(subst '(0 . "TEXT") '(0 . "ATTDEF")elist))
  7.   (setq elist(subst (cons 73 (cdr fawn)) fawn elist))
  8.   (mapcar '(lambda(x)  ;;匿名函数
  9.        (setq elist(vl-remove(assoc x elist)elist))
  10.        )
  11.     '(-1 330 5 100 100 100 3 2 70)
  12.     )
  13.   (entmake elist)
  14.   ;;(ai_undo_pop)
  15.   )
  16. (defun TEXTtoATTDEF(elist / ename fawn);;文本转属性
  17.   ;;(ai_undo_push)
  18.   (setq ename(cdr(assoc -1 elist)))
  19.   (entdel ename)
  20.   (setq fawn(assoc 73 elist))
  21.   (setq elist(subst '(0 . "ATTDEF") '(0 . "TEXT")elist))
  22.   (setq elist(subst (cons 74 (cdr fawn)) fawn elist))
  23.   (mapcar '(lambda(x)  ;;匿名函数
  24.        (setq elist(vl-remove(assoc x elist)elist))
  25.        )
  26.     '(-1 330 5 100 100 100)
  27.     )
  28.   (setq elist(append elist '((2 . "未命名属性")(3 . "请输入 未命名属性")(70 . 0))))
  29.   (entmake elist)
  30.   ;;(ai_undo_pop)
  31.   )
发表于 2012-11-11 12:11:40 | 显示全部楼层
fawn_lgc 发表于 2012-6-4 15:24
这个程序实用。
发表于 2012-11-11 13:38:26 | 显示全部楼层
刚刚需要这个程序就看到帖子
发表于 2013-2-2 10:48:09 | 显示全部楼层
fawn_lgc 老师的程序加载后,TEXTtoATTDEF作为命令,命令行显示【未知命令“TEXTTOATTDEF”。按 F1 查看帮助。】请问应该怎么用?谢谢
发表于 2013-2-8 21:57:13 | 显示全部楼层
psdcdr 发表于 2012-6-4 09:28
忘记在哪里找到的,一起分享下,
祝愿所有找LSP的朋友,都能得到答案!
非常感谢!!
发表于 2013-9-14 12:43:43 | 显示全部楼层
正在找这方面的资料,多谢大家分享。
发表于 2016-7-4 22:46:01 | 显示全部楼层
不能运行的。怎么办
发表于 2018-6-10 02:44:47 | 显示全部楼层
忘记在哪里找到的,一起分享下,
祝愿所有找LSP的朋友,都能得到答案!
谢谢,非常实用
GMT+8, 2025-12-21 04:41 , Processed in 0.175580 second(s), 29 queries , Gzip On.
