查看: 2925|回复: 4
圆孔批量标注
发表于 2012-6-3 15:10:46 | 显示全部楼层 |阅读模式
;圆孔批量标注
(DEFUN C:qdc(/ VAR1 VAR2 ENTGRP FLAG ENT TEMP1 OMODE OFFSET CENPT CRADIU PTX PTY  )
  (SETQ VAR1 (GETVAR "BLIPMODE"))
  (SETQ VAR2 (GETVAR "CMDECHO"))
  (SETVAR "BLIPMODE" 0)
  (SETVAR "CMDECHO"  0)             ; 系统变量设定﹚
  (SETQ COFFSET 2)
  (PRINT "标注实体:")
  (SETQ ENTGRP (SSGET '((0 . "CIRCLE"))))
  (SETQ FLAG (SSLENGTH ENTGRP))
  (setq omode (getvar "osmode"))              ;暂时关闭目标捕捉
  (setvar "osmode" 0)
  (REPEAT FLAG
      (SETQ ENT (SSNAME ENTGRP (1- FLAG)))
      (SETQ TEMP1 (ENTGET ENT))
      (SETQ CENPT (ASSOC 10 TEMP1))
      (SETQ CENPT (LIST (CADR CENPT) (CADDR CENPT)))
      (SETQ CRADIU (ASSOC 40 TEMP1))
      (SETQ CRADIU (CDR CRADIU))
      (SETQ XCOFFSET ( + (CAR CENPT) CRADIU COFFSET))
      (SETQ YCOFFSET (+ (CADR CENPT) CRADIU COFFSET))
      (SETQ ENT (LIST (CDR (ASSOC -1 TEMP1)) (LIST (+ CRADIU (CAR CENPT)) (CADR CENPT))))
(PRINC ENT) (PRINC "\N")
      (SETQ PTX (LIST XCOFFSET (CADR CENPT)))
      (SETQ PTY (LIST (CAR CENPT) YCOFFSET ))
      (SETQ PTDIA (LIST XCOFFSET YCOFFSET))
      (COMMAND "_DIMORDINATE" CENPT PTX)
      (COMMAND "_DIMORDINATE" CENPT PTY)
      (COMMAND "_DIMDIAMETER" ENT  PTDIA)
      (SETQ FLAG (1- FLAG))
  (SETVAR "OSMODE" OMODE)
  (SETVAR "BLIPMODE" VAR1)
  (SETVAR "CMDECHO"  VAR2)
发表于 2012-6-3 19:04:41 | 显示全部楼层
不赖啊,学习了。顶!
发表于 2012-6-3 19:26:33 | 显示全部楼层
好贴,学习了,顶!
发表于 2012-6-8 09:36:14 | 显示全部楼层
八错
发表于 2024-3-28 16:28:53 | 显示全部楼层
坐标不能自定义圆点
GMT+8, 2025-5-11 11:02 , Processed in 0.164154 second(s), 26 queries , Gzip On.
