2696| 7
求教GU版、龙仔、高飞鸟等等大侠们,DBX 修改块属性,显示不对的现象 |
1明经币
最佳答案insertionpoint属性要同时调
(DEFUN c:tt ()
(setq dbx (Vlax-Get-Or-Create-Object (strcat "ObjectDBX.AxDbDocument." (substr (getvar "acadver") 1 2))))
(vla-open dbx (SETQ PATH "E:\\属性块位移实验.dwg"))
(setq Model (Vlax-Get dbx 'ModelSpace)) ;为简便,仅获取模型空间内容
(vlax-for obj Model
(if (= (Vlax-Get obj 'ObjectName) "AcDbAttributeDefinition");因图中仅此一属性,获得即是该对象
(prog ...
评分 | ||
