- 积分
- 66427
- 明经币
- 个
- 注册时间
- 2010-5-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
自从AutoCAD使用"打断br"以来,就一直没有其逆操作Join。直到前几天,我试用2012版,发现Autocad已经翻然醒悟,Join出现了。
其实明经的网友们早就写了该程序,但写得复杂,我一直没有读懂。下面是我写的,写得很简单。经试试用,比2012版中的join要好用得多。
牛皮吹完了,不信你可以试一试。
;;;;; 共线直线并批量连接,相当于命令Join
(defun C:JOIN (/ E E1 EN EN1 I N ssLine)
;;1 p1是否在p2 p3线上,返回0.0
;;p1 is a point
;;p2 and p3 are points that form a line segment
;;returns 1 is p1 is on one side
;; -1 if on the other side
;; 0 if on the line
(defun what_side (p1 p2 p3 / a dx dx1 dy dy1)
(setq dx (- (car p3) (car p2))
dy (- (cadr p3) (cadr p2))
dx1 (- (car p1) (car p2))
dy1 (- (cadr p1) (cadr p2))
) ;setq
(setq a (- (* dx dy1) (* dy dx1))
a (rtos a 2 6)
a (atof a)
) ;setq
(if (not (equal 0.0 a))
(setq a (/ a (abs a))) ;setq
) ;if
a
) ;defun what_side
;;2 p1是否在p2 p3之间
(defun Between (p1 p2 p3)
(equal (+ (distance p1 p2) (distance p1 p3))
(distance p2 p3)
0.01
;;3 点表排序
(defun Sort_XYZ_pList (PLIST / p1 p2)
(setq plist (vl-sort plist
'(lambda (p1 p2)
(cond ((< (car p1) (car p2)) T)
((and (= (car p1) (car p2))
(< (cadr p1) (cadr p2))
T
(= (cadr p1) (cadr p2))
(< (caddr p1) (caddr p2))
T
(T nil)
;;4 与一条直线相连的所有直线
(defun joinLine (e e1 / EN EN1 P1 P2 P3 P4 PLIST)
(setq en (entget e))
(setq p1 (LI_item 10 en))
(setq p2 (LI_item 11 en))
(setq en1 (entget e1))
(setq p3 (LI_item 10 en1))
(setq p4 (LI_item 11 en1))
(if (and (equal (what_side p3 p1 p2) 0.0)
(equal (what_side p4 p1 p2) 0.0)
(or (Between p3 p1 p2) (Between p4 p1 p2));对pdf转换成的dwg,不要这句更妥
(setq Plist (Sort_XYZ_pList (list p1 p2 p3 p4)))
(setq p1 (car Plist))
(setq p2 (car (reverse Plist)))
(setq en (subst (cons 10 p1) (assoc 10 en) en))
(entmod (subst (cons 11 p2) (assoc 11 en) en))
(command "_.erase" e1 "")
;;5 本程序主程序
(setq ssLine (ssget '((0 . "LINE"))))
(repeat (setq n (sslength ssLine))
(if (and (setq e (ssname ssLine (setq n (1- n))))
(repeat (setq i n)
(if (and (setq e1 (ssname ssLine (setq i (1- i))))
(joinLine e e1)
(princ "\n written by 自贡黄明儒 命令:Join")
