查看: 1794|回复: 0
哪位帮我看看这段复制后变颜色的代码,谢谢先
发表于 2012-6-9 18:44:03 | 显示全部楼层 |阅读模式
我需要一个跟CAD的复制一样的程序,区别是复制后新生的对象颜色都变为红色。
下面这段程序基本上可以实现,但是没有copy那样被复制的对象随着鼠标预显示出来,多重复制时需要回车等等缺陷。
好心的朋友帮我改改,或者简单的话推倒重来,谢谢先
  1. (defun c:cc (/ ss n pt1 ptn pt plist i j ssa enty lastent obj)  (vl-load-com)  (setq        AcadObject   (vlax-get-acad-object)        AcadDocument (vla-get-ActiveDocument AcadObject)        mSpace             (vla-get-ModelSpace AcadDocument)  )  (prompt "请选择要复制的对象")  (setq ss (ssget))  (setq pt1 (getpoint "拾取基点"))  (setq ptn (getpoint pt1 "拾取第二点"))  (setq n 1)  (while ptn    (setq plist (append plist ptn))    (setq ptn (getpoint pt1 "拾取第二点"))    (setq n (1+ n))  )  (setq i 0)  (setq ssa (ssadd))  (while (< i (sslength ss))    (setq enty (ssname ss i))    (setq j 0)    (repeat n      (setq pt (list (nth j plist)                     (nth (+ 1 j) plist)                     (nth (+ 2 j) plist)               )            j  (+ 3 j)      )      (command "copy" enty "" pt1 pt)      (setq lastent (entlast))      (ssadd lastent ssa)      (setq obj (vlax-ename->vla-object lastent))      (vla-put-color obj acRed)    )                                        ;repeat    (setq i (1+ i))  )                                        ;while)
GMT+8, 2025-6-7 04:44 , Processed in 0.160652 second(s), 30 queries , Gzip On.
