查看: 17560|回复: 77
有记忆的移动
发表于 2012-6-10 15:41:09 | 显示全部楼层 |阅读模式
因为常用到往同一方向移动同一距离,所以就写了个小程序,希望对各位也有点小用,有记忆功能的,如下
怎么看不到啊,怎么下载  发表于 2015-12-16 19:55
朋友,怎么一运行程序就变成了正交模式?这样移动还得关掉正交,就算关掉正交,下一次移动时又成正交模式了,这个能改一下吗?  发表于 2012-8-24 11:54
发表于 2012-6-14 17:02:47 | 显示全部楼层
  1. (defun c:jyyd (/ s_disyd)
  2.   (princ "\n<<<欢迎使用记忆移动功能>>>")
  3.   (setvar "ORTHOMODE" 1)
  4.   (command ".MOVE" (ssget) "")
  5.   (command (setq basicpoint (getpoint "\n指定基点:")))
  6.   (if (= nil s_dis_allyd)
  7.     (progn
  8.       (setq s_dis_allyd (getreal "\n输入移动距离:"))
  9.       (command s_dis_allyd)
  10.     )
  11.     (progn
  12.       (setq s_disyd (getreal (strcat "\n输入拉伸距离<" (rtos s_dis_allyd 2 4)
  13.                                      ">:"
  14.                              )
  15.                     )
  16.       )
  17.       (if (= nil s_disyd)
  18.         (setq s_disyd s_dis_allyd)
  19.       )
  20.       (command s_disyd)
  21.       (setq s_dis_allyd s_disyd)
  22.     )
  23.   )
  24.   (setvar "ORTHOMODE" 0)
  25.   (princ "\<<<记忆移动执行完毕!>>>")
  26.   (princ)
  27. )
取自明经,各有优劣
回复 支持 1 反对 1
发表于 2016-5-3 09:55:40 | 显示全部楼层
zhong876158 发表于 2014-9-20 09:34
有同感,运行后影响了正交模式
照着论坛记忆拉伸的程序改成了记忆移动,同时感谢Z大!
;;;;========================记忆移动============================
;源地址http://bbs.mjtd.com/forum.php?mo ... 1&fromuid=38464
(defun c:MM (/ basicpoint old_ORTHOMODE pt)
  (setq old_ORTHOMODE (getvar "ORTHOMODE"))
  (if (= nil S_distance)
    (progn (setq S_distance (getreal "\n输入移动距离:"))
    (progn (setq s_disyd (getreal
                           (strcat "\n输入移动距离<" (rtos S_distance) ">")
           (if (= nil s_disyd)
             (setq s_disyd S_distance)
           (setq S_distance s_disyd)
  (command ".move" (ssget) "")
  (setq pt (getpoint basicpoint "\n指定方向:"))
  (command basicpoint
           (polar basicpoint (angle basicpoint pt) S_distance)
  (setvar "ORTHOMODE" old_ORTHOMODE)
;;;;================记忆移动100 200 300 400 50==================
(defun c:M1 (/ S_distance basicpoint old_ORTHOMODE pt)
  (setq S_distance 100)
  (command basicpoint (polar basicpoint (angle basicpoint pt) S_distance))
(defun c:M2 (/ S_distance basicpoint old_ORTHOMODE pt)
  (setq S_distance 200)
(defun c:M3 (/ S_distance basicpoint old_ORTHOMODE pt)
  (setq S_distance 300)
(defun c:M4 (/ S_distance basicpoint old_ORTHOMODE pt)
  (setq S_distance 400)
(defun c:M5 (/ S_distance basicpoint old_ORTHOMODE pt)
  (setq S_distance 50)
发表于 2020-8-31 16:18:04 | 显示全部楼层
海盗曹 发表于 2012-6-14 17:02
取自明经,各有优劣
谢谢大神的分享,用处大大的用
发表于 2012-6-10 16:18:40 | 显示全部楼层
下载要记得回帖一下
发表于 2012-6-10 18:28:09 | 显示全部楼层
顶。试用一下。
发表于 2012-6-10 18:36:25 | 显示全部楼层
谢谢楼主,又学一招
发表于 2012-6-10 19:02:05 | 显示全部楼层
先看看好不好用,哈
发表于 2012-6-11 06:28:38 | 显示全部楼层
谢谢 顶顶顶
发表于 2012-6-11 13:11:23 | 显示全部楼层
这个不错,支持一下,刚好需要.
试了一下,
如果能只记忆距离,方向由鼠标来定+加空格确定移动,就好了.
发表于 2012-6-12 10:10:52 | 显示全部楼层
源码的,就得支持!
下来,学习一下!
发表于 2012-6-12 12:29:20 | 显示全部楼层
昨天忘记回铁了
发表于 2012-6-12 13:02:53 | 显示全部楼层
试用一下。。。。。
GMT+8, 2025-5-20 13:56 , Processed in 0.217433 second(s), 35 queries , Gzip On.
