查看: 1620|回复: 0
如何获取txt文件中的多行文字,并按指定条件插入
发表于 2012-6-13 16:09:45 | 显示全部楼层 |阅读模式
首先要获取 多行语言,然后用getpoint取得批文字的插入点,用getdist取得指定的字高
我的这个似乎有问题
(SETQ datafile (GETFILED "" "" "txt" 2))
(setq ff (open datafile  "r"))
(setq aa (read-line ff))
(setq point (getpoint "请确定一点:"))
(setq hh (getdist point "\n请输入字高"))
(setq cenpt (getpoint "请求确定一点"))
(command "-mtext" point "H" hh cenpt aa  "")
(while aa
     (command aa)
(command "")
(close ff)
GMT+8, 2025-5-23 00:15 , Processed in 0.206449 second(s), 30 queries , Gzip On.
