查看: 2360|回复: 3
释放不掉的局部变量!1
发表于 2012-6-18 19:17:48 | 显示全部楼层 |阅读模式
小的写了条程序,不知是哪里写错了,死活就是不能把局部变量给释放掉,求助于高手!
如以下程序,局部变量( t1 mn i ni ay ax n t2 str k a1 a10 fom)死活去不掉!!
(defun c:qf( / t1 mn i ni ay ax n t2 str k a1 a10 fom)
  (setvar "osmode" 0)
  (print "<QF编码>功能已开启")
  (princ ">>请选择对象...")
  (setq nu(ssget (list '(0 . "INSERT") '(8 . "1"))))
  (setq t1 1)
  (form1)
  (setq i 0 n 0)
  (repeat (sslength nu)
    (setq mn(nth n fom))
    (setq i 0)
      (setq ni(entget(ssname nu i)))
      (setq ax(cadr(assoc 10 ni)))
      (setq ay(- (caddr(assoc 10 ni)) 12.69))
(if (= mn ax)
   (progn (setq ax(+ 4.61 (cadr(assoc 10 ni)))) (xt))
      (setq i(1+ i))
    (setq n(1+ n))
  (setvar "osmode" 15359)
(defun xt()
  (setq t1(rtos t1))
  (setq t2(strcat t1 "QF"))
  (setq text(list (cons 0 "TEXT") (cons 102 "{ACAD_REACTORS") (list 10 ax ay 0.0) (cons 40 3) (cons 1 t2) (cons 8 "2")))
  (entmake text)
  (setq t1(atof t1))
  (setq t1(+ t1 1))
(defun form1()
  (setq str nil k 0)
    (if (ssname nu k);判断是否存在下一个图素
      (progn (setq a1(entget(ssname nu k)))
        (setq a10(cadr(assoc 10 a1)))
(setq str(append str (list a10)))
    (setq k(1+ k))
  (setq fom(vl-sort str '<))
发表于 2012-8-15 10:03:37 | 显示全部楼层
试过了,没有出现不能释放的情况,是不是执行中出错了啊?
发表于 2012-8-15 22:37:45 | 显示全部楼层
猜是 命令列 所设定的变量值
Command: (defun C:test (/ a b) (setq a 1 b 2) (+ a b))
C:TEST
Command: test
3
Command:
Command: !a
nil
Command: (setq a 5)
5
Command: test
3
Command:
Command: !a
5
发表于 2013-2-28 12:27:05 | 显示全部楼层
我同样遇到这样的问题,请问该怎么解决哈
GMT+8, 2025-5-24 23:29 , Processed in 0.178083 second(s), 23 queries , Gzip On.
