- 积分
- 4518
- 明经币
- 个
- 注册时间
- 2011-11-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2021-11-27 16:32:07
显示全部楼层
 - Sub InstBlk()
- '插入一个含有自定义属性的匿名块
- '添加一个圆
- Dim blockObj As AcadBlock
- Dim insertionPnt(0 To 2) As Double
- insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
- Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "*U")
- Dim circleObj As AcadCircle
- Dim center(0 To 2) As Double
- Dim radius As Double
- center(0) = 0: center(1) = 0: center(2) = 0
- radius = 1
- Set circleObj = blockObj.AddCircle(center, radius)
- '添加一个属性
- Dim attributeObj As AcadAttribute
- Dim height As Double
- Dim mode As Long
- Dim prompt As String
- Dim insertionPoint(0 To 2) As Double
- Dim tag As String
- Dim value As String
- ' 定义属性定义
- height = 1#
- mode = acAttributeModeNormal
- prompt = "新提示"
- insertionPoint(0) = 0#: insertionPoint(1) = 0#: insertionPoint(2) = 0
- tag = "新标签"
- value = "显示的属性值"
- ' 在模型空间中创建属性定义对象
- Set attributeObj = blockObj.AddAttribute(height, mode, prompt, insertionPoint, tag, value)
- attributeObj.Invisible = False
- attributeObj.Alignment = acAlignmentMiddleCenter
- Dim BlkName As String
- BlkName = GetUNBlock
- Dim blockRefObj As AcadBlockReference
- insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
- Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, BlkName, 1#, 1#, 1#, 0)
- End Sub
- Public Function GetUNBlock() As String
- Dim n As Integer
- For Each blockObj In ThisDrawing.Blocks
- If Left(blockObj.Name, 1) = "*" Then
- If blockObj.Name <> "*Model_Space" And Left(blockObj.Name, 12) <> "*Paper_Space" Then
- If Mid(blockObj.Name, 3) >= n Then
- n = Mid(blockObj.Name, 3)
- GetUNBlock = blockObj.Name
- End If
- End If
- End If
- Next
- Set blockObj = Nothing
- End Function
