查看: 1286|回复: 3
求一句话
发表于 2012-6-28 10:25:19 | 显示全部楼层 |阅读模式
判断如果图层a锁定则解锁,请指教怎样写
发表于 2012-6-28 10:31:59 | 显示全部楼层
(if (= 4 (logand (cdr (assoc 70 (entget(tblobjname "layer" strlayer)))) 4)) (command "layer" "u" strlayer ""))
谢谢指导  发表于 2012-6-28 15:59
发表于 2012-6-28 11:12:05 | 显示全部楼层
(if(= :vlax-true (vla-get-lock (setq lay(vla-item(vla-get-layers(vla-get-ActiveDocument(vlax-get-acad-object))) "a"))))
  (vla-put-lock lay  :vlax-false)
谢谢!很好!  发表于 2015-10-20 21:38
谢谢指导  发表于 2012-6-28 17:22
发表于 2012-6-28 11:52:40 | 显示全部楼层
高手们都出现了,学习下!
GMT+8, 2025-7-22 03:57 , Processed in 0.177646 second(s), 30 queries , Gzip On.
