查看: 5882|回复: 26
★边坡台阶自动开挖程序求实现
发表于 2012-6-29 17:46:55 | 显示全部楼层 |阅读模式
工作中经常遇到在边坡开挖台阶,要求台阶高0.5m,宽为整数(即n×0.1m,如0.4m、0.5m等),且按照现状地形最大限度开挖,见图红色线为现状地面线,白色线为开挖台阶线。我的思路是这样的,先按照0.5m高度阵列与地形线相交,然后求出每个台阶与地形线相交的水平长度,对长度取整,最后连点成线,不知道哪位大侠能帮忙给个程序。
发表于 2012-7-4 21:57:10 | 显示全部楼层
参考效果:
发表于 2020-2-28 09:13:39 | 显示全部楼层
这个非常好用,感谢nnnnnnnnnn兄
发表于 2019-11-26 11:17:11 | 显示全部楼层
需要这个插件,实用
 楼主| 发表于 2012-6-30 09:29:10 | 显示全部楼层
这样的思路也应该可以,画线从最上面顶点开始,读取所有多段线线顶点坐标,按竖向排序,求任意第i阶y坐标(0.5m×i)对应的x坐标,对x坐标取整,然后去取得任意i阶坐标,最后连点成线。
 楼主| 发表于 2012-6-30 18:22:46 | 显示全部楼层
(setq PT (vlax-curve-getpointatdist Ent 1))这个能按曲线长度获取点,
请问怎样才能按照垂直高度每隔0.5m在多段线上获取点呢?
发表于 2012-6-30 21:27:34 | 显示全部楼层
需要做辅助水平线,然后intersectwith求交点
 楼主| 发表于 2012-7-1 00:08:21 | 显示全部楼层
麻烦mmmmmm 大哥写一段程序了,小女比较笨笨
发表于 2012-7-2 13:33:35 | 显示全部楼层
(Defun c:zz()(_DrawSect (car (entsel))))
(Defun _DrawSect (pl           /            _GetPlineVertex   _FixRoundX
                  INT           LL            OBJ             P1              P2       PLX
                  RTN           UR            VLO
  (Defun _FixRoundX (pt base / x)
    (setq x (car pt)
          x (* 100 (fix (+ 0.5 (* x 0.01))))
    (list x (cadr pt))
  (Defun _GetPlineVertex (ptx / PT0 PT1 RTN X0)
    (setq x0 (caar ptx))
    (while (cdr ptx)
      (setq pt0        (_FixRoundX (car ptx) x0)
            pt1        (_FixRoundX (cadr ptx) x0)
            rtn        (append        (list (list 10 (car pt1) (cadr pt0))
                              (list 10 (car pt0) (cadr pt0))
                        rtn
            ptx        (cdr ptx)
    (setq
      rtn (append (list (list 10 (car (last ptx)) (cadr (last ptx))))
                  rtn
    rtn
  (setq vlo (vlax-ename->vla-object pl))
  (vla-getboundingbox vlo 'll 'ur)
  (setq        ll (trans (vlax-safearray->list ll) 0 1)
        ur (trans (vlax-safearray->list ur) 0 1)
  (setq        p1 (polar ll pi (* 0.1 (- (car ur) (car ll))))
        p2 (polar ll 0 (* 1.2 (- (car ur) (car ll))))
  (entmake (list (cons 0 "line") (cons 10 p1) (cons 11 p2)))
  (setq obj (vlax-ename->vla-object (entlast)))
  (while
    (and
      (setq int (vla-intersectwith vlo obj acExtendNone))
      (null
        (vl-catch-all-error-p
          (vl-catch-all-apply
            '(lambda ()
               (setq
                 int (vlax-safearray->list (vlax-variant-value int))
      (= (length int) 3)
     (setq rtn (cons int rtn))
     (vla-move obj
               (vlax-3d-point '(0. 0. 0))
               (vlax-3d-point '(0. 500. 0.))
  (vla-erase obj)
  (setq        rtn (_GetPlineVertex
              (vl-sort rtn '(lambda (p1 p2) (< (cadr p1) (cadr p2))))
        plx (append (list (cons 0 "lwpolyline")
                          (cons        100
                                "AcDbEntity"
                          (cons 100 "AcDbPolyline")
                          (cons 90 (length rtn))
                    rtn
  (entmake plx)
 楼主| 发表于 2012-7-2 23:56:21 | 显示全部楼层
非常感谢mmmmmm 大哥,太神了,基本达到了我需要的功能,美中不足的就是开挖台阶线即白色线部分越过了红线,另外最上面的竖向开挖边不垂直,还有就是起始点想要从红线开始,更完美的话就是起始点可选择从上面或从下面开始。还是麻烦大哥再修饰修饰一下。。。
 楼主| 发表于 2012-7-3 00:20:27 | 显示全部楼层
不好意思,我的表达有误,最后一根线垂直得了,可以不受0.5m限制
发表于 2012-7-3 10:32:23 | 显示全部楼层
突出的区域还是用眼和手修改吧,程序要判断处理的话,要判断曲线的形状走向以及特定点的哪个方向是土,代码估计要长出一倍去。
 楼主| 发表于 2012-7-3 22:27:53 | 显示全部楼层
好的,还是要谢谢你大侠,虽然有点修改,但还是方便很多。
GMT+8, 2025-10-1 08:50 , Processed in 0.226353 second(s), 32 queries , Gzip On.
