查看: 2738|回复: 5
记得以前找了个LSP可以查看我所有的LSP里用了那些命令
发表于 2012-6-30 15:13:32 | 显示全部楼层 |阅读模式
记得以前找了个LSP可以查看我所有的LSP里用了那些命令的LSP
现在这个铁子怎么找不到了,那位知道那有不
发表于 2012-6-30 15:38:12 | 显示全部楼层
ET工具,加载后,lsp命令可用了
 楼主| 发表于 2012-6-30 15:52:37 | 显示全部楼层
不不不它不是ET里的吧
我以前用那个LSP生成一个文件如下,现在却不知道放那了,只有生成的文件在
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/1   刷上一次选择.LSP" '("1"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/2007[1][1].11.16带对话框omnipotence.LSP" '("LXX" "CH" "LTS" "REFEDIT" "OP" "REA" "AA" "POL" "REC" "C" "DO" "EL" "REG" "DIV" "ME" "AR" "E" "EX" "S" "LEN" "SC" "CHA" "F" "ED" "DLI" "DAL" "QDIM" "DCO" "DRA" "WIPEOUT" "WMFOUT" "CU" "DC" "SC" "A2" "V" "FZ" "33" "3" "SA" "EA" "E3" "HZ" "VH" "2" "EF" "CX" "CC" "X" "DX" "SX" "GX" "R" "CS" "DA" "G" "SS" "AD" "T" "TT" "3T" "HQ" "ES" "Q" "WS" "DDQ" "DQ" "FW" "NE" "CHG" "CHC" "GG" "FF" "RR" "VV" "EE" "FD" "D" "*" "*" "XZ" "RC" "4" "5" "HG" "3H" "3F" "LM" "FZM" "CL"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/2D          3D 坐标 改 2D.lsp" '("2D"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/ACAD11.LSP" '("AEE" "AE" "FC" "C1" "C2" "C3" "C4" "C5" "C6" "C7" "C8" "C9" "C42" "CB" "5" "CHH" "CH2" "CHC" "CHD" "3" "4" "6" "7" "8" "FA" "1" "0" "30" "45" "60" "ZR" "ZA" "ZD" "ZE" "2" "BP" "BB" "VS" "FR" "WR" "FX" "FE1" "FE" "FW" "SV" "RG" "CM" "PLA" "VT" "VL" "TH" "HL" "SL" "BC" "XT"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/ACH    批改属性块文字.LSP" '("ACH"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/BBC            选择层.lsp" '("BBC"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/BE    打断.lsp" '("BE"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/Block1    块替换.lsp" '("CHB" "CBR"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/DE    移至当前层.LSP" '("DE"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/E1  &   E2    两点画引线.lsp" '("E1" "LD3" "E2"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/HT     拿一个文字与别文字合并.LSP" '("HT"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/KK  图层合并.lsp" '("KK"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/LE.LSP" '("LE" "LEE" "3E" "4E"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/SE  安装YOU TOOL.LSP" '("SE"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/SG    拾取层为当前层.LSP" '("SG"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/TEA  快速建组  DET   快速炸组  99  组的开和关.lsp" '("TEA" "DET" "99"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/Text    对齐 .LSP" '("TV" "TH"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/VOL   随层.lsp" '("VOL"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/X1    圆管双折线.lsp" '("YZJD" "X1"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/xyz转.lsp" '("XYZ" "XG" "YG" "ZG" "MG" "RQ"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/断开块内线.lsp" '("BLKTRIM"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/视窗view.lsp" '("VDE" "VDS" "VDN" "VDW" "VDT" "VDL" "VDB" "VDR" "VDF" "VDK"))
(autoload "D:/D/MY TOOL/MYTOOL/经常用的/迷你建筑用于画建筑的几个命令.lsp" '("VQ" "VW" "VE" "VR" "VA" "VS" "VD" "VZ" "VX" "VC" "VF" "VB" "CE" "CW"))
 楼主| 发表于 2012-7-2 09:12:25 | 显示全部楼层
有那位知道不
发表于 2012-7-2 09:43:51 | 显示全部楼层
这个还真的没有见过啊
发表于 2012-7-2 20:59:31 | 显示全部楼层
357785513 发表于 2012-6-30 15:52
不不不它不是ET里的吧
(autoload ...
你好,你那个圆管双折线.lsp是什么形式的?
GMT+8, 2025-7-22 01:12 , Processed in 0.185854 second(s), 26 queries , Gzip On.
