查看: 1563|回复: 2
userform1.show显示无效外部过程
发表于 2012-7-14 10:24:06 | 显示全部楼层 |阅读模式
网上有说,没有“microsoft windows command controls”引用的,我看了下,确实找不到。regsvr32 mscomctl.ocx后,仍然没有
求解决
  1. '传递标注非关联长度数据
  2. Public angletext As String
  3. '传递按钮选择的对象集
  4. Public sel As AcadSelectionSet
  5. Load UserForm1
  6. UserForm1.Show
  7. Sub DIM_CHANGE()
  8. Dim dimselect As AcadDimAligned
  9. Dim ent As AcadEntity
  10. Set ent = sel.Item(0)
  11. If ent.ObjectName = "AcDbAlignedDimension" Then
  12. Set dimselect = ent
  13. End If
  14. Set angeltext = TextBox1.Text
  15. dimselect.TextOverride = Val(angletext)
  16. Set sel = Nothing
  17. ThisDrawing.SelectionSets("a").Erase
  18. End Sub
该贴已经同步到 Flyingdancing的微博
发表于 2012-7-15 09:58:41 | 显示全部楼层
  1. Load UserForm1
  2. UserForm1.show
复制代码
这两行必须放到过程里面啊,在模块的声明段当然会出错了.
PS:Load UserForm1这一行多余
 楼主| 发表于 2012-7-15 12:58:19 | 显示全部楼层
谢谢
GMT+8, 2025-5-29 05:48 , Processed in 0.144142 second(s), 24 queries , Gzip On.
