查看: 3576|回复: 3
使用arraypolar错哪了郁闷啊
发表于 2012-7-17 15:39:12 | 显示全部楼层 |阅读模式
(defun c:test3()
  (setq baspt (getpoint "请求输入基准点"))
  (setq rad (getdist "\n请求输入基小圆半径"))
  (setq num (getint "\n请求输入相切小圆数量"))
  (setq ang1 (/ (* pi 2) (* num 2)))
  (setq kk (/ rad (sin ang1)))
  (setq ang2 (- (/ pi 2) ang1))
  (setq cenpt (polar baspt ang2 kk))
  (command "circle" baspt rad)
  (command "arraypolar" (entlast) "" cenpt num "" "")
  (prin1)
(prompt "\n<<test3>>自动等圆相切绘制")
(prin1)
发表于 2012-7-17 17:55:50 | 显示全部楼层
arraypolar ? 哪里的命令?
 楼主| 发表于 2012-7-17 20:10:22 | 显示全部楼层
CAD2012环形阵列
发表于 2015-12-18 15:05:53 | 显示全部楼层
(defun c:test3()
  (command "arraypolar" (entlast) "" cenpt "e" num "" "")
  (prin1)
(prin1)
GMT+8, 2025-5-2 05:31 , Processed in 0.144443 second(s), 29 queries , Gzip On.
