查看: 3663|回复: 13
检查线段是否断开。。。
发表于 2012-7-19 10:42:32 | 显示全部楼层 |阅读模式
路过高手帮看看。。。发贴好多次了。。。无人解决。。。
论坛里仔细搜搜,类似问题我给过答案的!  发表于 2012-7-19 21:58
发表于 2017-8-23 22:59:56 | 显示全部楼层
;;;*****查悬挂线 程序开始*****
(defun C:T1 (/ ptList ptNo)
  (princ "\n★功能:查找悬挂断开的线段集\n")
  (setvar "pickadd" 1)
  (setvar "osmode" 15359)
  (setvar "PICKDRAG" 0)
  (setvar "cmdecho" 0)
                                        ;  (wdy_timeset1)
  (command "undo" "be")
  (princ "\n请选取直线、多段线、样条曲线、圆弧:")
  (if (not (setq ss (ssget '((0 . "*LINE,ARC")))))
    (progn (princ "\未选中对象。程序退出!") (exit))
  (initget 6)
  (if (not (setq jd (getreal "\n输入模糊距离:<0.001>"))) (setq jd 0.001))
  (initget 1)
  (setq ptBase (getpoint "\n指定标记引出线的位置点:"))
  (command "LAYER" "M" "层标记-悬挂线" "C" "1" "层标记-悬挂线" "")
  (setvar "osmode" 0)
  (vl-load-com)
  (setq        i -1
        ptList nil
        ptNo nil
  (repeat (sslength ss)
    (setq entnam  (ssname ss (setq i (1+ i)))
          obj          (vlax-ename->vla-object entnam)
          ptStart (vlax-curve-GetStartPoint obj)
          ptEnd          (vlax-curve-GetEndPoint obj)
    (if        (not (vlax-curve-isclosed obj))
        (setq ptList (cons ptStart ptList))
        (setq ptList (cons ptEnd ptList))
  (prin1 ptList)
  (while (setq pt     (car ptList)
               ptList (cdr ptList)
    (if        (wdy_cxgx_duibi pt ptList jd)
      (setq ptList (vl-remove pt ptList))
      (setq ptNo (cons pt ptNo))
  ;| (while (setq pt     (car ptList)
               ptList (cdr ptList)
    (if        (member pt ptList)
  )|;                                        ;另一种写法,无精度判断,算法较差
  (if (not ptNo)
    (alert "提示:\n恭喜你!没有发现悬挂线对象。\n")
      (foreach pt ptNo
        (command "LINE" pt ptBase "")
      (alert
        "提示:\n发现了悬挂线对象!\n\n请根据“层标记-悬挂线”图层中的引出线位置点进行查看悬挂线位置点。\n"
  (command "undo" "e")
(defun wdy_cxgx_duibi (pt0 lst jd / TorF x)
  (setq TorF nil)
  (foreach x lst
    (if        (equal pt0 x jd)
      (setq TorF T)
  TorF
;;;*****查悬挂线 程序结束*****
 楼主| 发表于 2012-7-19 10:45:50 | 显示全部楼层
  1. (defun c:ccc()
  2.      (if (setq ssa (ssget '((0 . "LINE"))))
  3.          (progn
  4.              (setq ptb nil  i -1)
  5.              (repeat (sslength ssa)
  6.            (setq dxf (entget (ssname ssa (setq i (1+ i))))
  7.           p10 (cdr (assoc 10 dxf))
  8.           p11 (cdr (assoc 11 dxf))
  9.    ptb (cons p11 (cons p10 ptb))
  10.            )
  11.       )
  12.              (setq jgb nil fhz nil)
  13.              (while (setq pt  (car ptb)
  14.             ptb (cdr ptb)
  15.       )
  16.                  (if (member pt ptb)
  17.        (setq ptb (vl-remove pt ptb)
  18.       fhz (cons pt fhz)
  19.        )
  20.        (setq jgb (cons pt jgb))
  21.    )
  22.
  23.       )
  24.       (mapcar '(lambda(x) (command "_circle" x 50)) jgb)
  25.
  26.       ;变量tymlb储存刚好首尾相接直线的图元名列表
  27.       (setq tymlb nil)
  28.       (foreach pt fhz
  29.                  (setq ssa (ssget "c" pt pt '((0 . "LINE")))
  30.          i   -1
  31.    )
  32.           (repeat (sslength ssa)
  33.        (if (not (member (setq ent (ssname ssa (setq i (1+ i)))) tymlb))
  34.            (setq tymlb (cons ent tymlb))
  35.        )
  36.    )
  37.       )
  38.   )
  39.      )
  40.      (princ)
  41. )
 楼主| 发表于 2012-7-19 10:47:24 | 显示全部楼层
上面是论坛源吗。。只支持直线。。。
高手们帮改个对直线,圆弧,圆,多段线,样条曲线,二维三维多段线都支持的。。。
 楼主| 发表于 2012-7-19 10:53:58 | 显示全部楼层
  1. (defun c:ccc()
  3.          (progn
  10.            )
  11.       )
  14.             ptb (cdr ptb)
  15.       )
  19.        )
  21.    )
  22.
  23.       )
  25.
  28.       (foreach pt fhz
  30.          i   -1
  31.    )
  35.        )
  36.    )
  37.       )
  38.   )
  39.      )
  40.      (princ)
  41. )
 楼主| 发表于 2012-7-19 10:54:32 | 显示全部楼层
这是论坛另一源码。。。都只支持直线
 楼主| 发表于 2012-7-19 10:55:59 | 显示全部楼层
 楼主| 发表于 2012-7-19 10:56:58 | 显示全部楼层
在线等。。。难道只有悬赏贴有人回复。。。解决吗。。。
发表于 2012-7-19 11:21:27 | 显示全部楼层
楼主要求不明,难怪无人回答。是不是想检查线、弧是否围成了封闭图形?
(> (sslength (ssget "c" pt pt '((0 . "*LINE,ARC"))) 1)
;;pt为端点
发表于 2012-7-19 12:45:55 | 显示全部楼层
去下载个燕秀,有这功能
 楼主| 发表于 2012-7-28 14:04:20 | 显示全部楼层
(> (sslength (ssget "c" pt pt '( ...
你仔细看要求了吗。。
GMT+8, 2025-12-6 07:15 , Processed in 0.199137 second(s), 36 queries , Gzip On.
